little lift- BIG tires
was reading this article on autoblog The "jeeps" of Iceland: here there do be monsters - Autoblog
and saw this freakin awesome 08 350
has anyone here done anything like that? the article states the truck has only a 5 inch lift and 40" tires.
I read an article about five years ago that focused on the iceland adventure trucks made out of land rovers. AEV has done this with Jeep Wranglers. And, there was an show on TV that had a Toyota Landcruiser with 40 inch tires and a small lift. If you find anything, share.
Also, I don't think the fenders will get torn off. From what I remember, the suspensions and fenders are modified pretty extensively.
Did a quick search and found this article--not sure if this is where you found the original picture.
EDIT--Doh! I missed the link in the first post.
oh come on, this truck is built to go, these things are def. not pavement pounders, they cross glaciers with them.
a dodge, but truly a badass machine
So he took Unimog pieces like the axles and brakes, and mounted those on the Dodge. Notice that the hubs are below the axles, for extra clearance. There's an extra transfer case for extremely low gearing. There's an extra gas tank. Then he threw 54-inch tires. The tires are bolted to the rims. The air pressure can be controlled from inside the cabin. There's an additional valve on the rim to let air out quickly. And do you know what he did then? He ran over the Earth.
i got a kick out of that line.
i'd love to get some 37's under my '00 with the 4 inch lift.
He added portal axles--either from a unimog or a volvo truck--so that the hubs are below the axles using gears to drive the axle. The wheels are bead locks--the lock plate sandwiches the tire between the wheel and the plate using bolts.
I'm liking that black super duty crew cab--a whole lot! By the way, I have 35s (315/170) on my 2005 with stock suspension. I would guess I could get 40s on the truck if I added a 5 inch lift, cut the fenders and changed the offest on wider wheels without any problems. Those trucks would be great at the beach or the hunting lease if it was muddy.
Normally when they build these suspensions like this they build them for extension and not compression. So right now there is probably only a few inches of uptravel until it hits a bumpstop, but there is a whole lot of downtravel.
A lot of the jeepers I go wheeling with are tending to build their rigs this way now to keep the center of gravity down.
Interesting...
