97 460 needs cheap power
I have a 97 crew cab with a 460 bone stock engine. only upgrade at this point is a K&N air filter with a trimmed up air inlet and a decent exhaust with a gutted cat. I use it for a daily driver but also pull in a stock truck pulling class. I need some quick inexspensive power upgrades just to get the tires turning. 33x12.50x16.5 mud tires on old style white spoke wheels. Any suggestions would be much appreciated. thanks.
put a timing chain from a 1970 460 in it. It will change the cam timing back to straight up. I assume they don't check emissions real closely if you have a gutted cat. This is supposed to be a night and day difference. I never ran my motor before I changed it but its a bone stock 460 with 3.55 gears and 33's and its got plenty of wheel spinning power.
68-71 they had cam timing set to straight up. After that they changed cam timing to satisfy tougher emmissions standards. This was not good for power. I have a carbed 460 but I guy I work with has a 460 tow rig that had this mod done to it when he bought it, its injected and as far as I know its fine. Hopefully someone else can chime in here?
I do know that by chopping off the little air restricting cone shaped things in the plastic peice of the air inlet (between the hoses), I gained alot of power. And the engine doesn't sound like its sucking for air any more and gave the exhaust a much nicer bellowing sound. I can't believe those cone shaped things were even there.
I'd put a MSD on it. i dont know much about the injection, infact i asked in a post myself, but hotter spark is always a shure bet. Just make shure you do the wires, coil and cap/rotor with all MSD or sim. parts. Having a hot box and stock wires will only cause problems. It will take a few $ but it pays for itself over time, keeps oil clean abit longer, and adds power over total power range.
