wierd engine noise
wierd engine noise
i put this 390 in my truck and ive put a thousand miles on it and last weekend we went campin and it started makin a wierd noise as i was shuttin it off kinda sounded like it was overheated but the gauge says normal it only does this when i get into the throttle on the road and then get home and shut it off thats when i hear it im not sure if its still gettin broke in or if somethin is goin on with it
Ok the noise sounds like the kind of squeal you have after a motor has overheated, or when it is overheatin. Its around the water pump but everything on the motor is new as far as the coolin system goes. No knockin or hissin just a squeal at idle that keeps goin until i shut it off. The radiator is from the 75 parts truck and is a super cooler. I flushed out the radiator before i put it in and the water pump, thermostat, and woses are all new. The only thing that aint is the radiator. I did put the shroud on it along with a new fan clutch. Sorry for the bad typin im not too good with it.
No them are new too and we tightened em up good. I just went out and checked and it aint that. I also got a long pry bar and put my thumb on the end of it and put my ear on my thumb, put it on the alt, ps, and water pump and they all sounded good alt belt was a little loose. So tightened that up and it didnt do a thing for it. Now that i litened to all that im wonderin if its the crank snout rubbin on the timing cover seal?
Just kidding, man.
I still would say you have a belt issue if I understand you right. I'd suggest, as a cheap an easy way to find out, trying that tooth paste idea that Ben suggested. Then if it goes away with the paste, you'll know. If not, then you probably eliminated one thing without spending money on a belt..or taking time to change it.
Check your alternator pulley-I had one that got loose-it would work fine until it was loaded at idle, and would squeal and chirp. Turned out the fan was cracking too-on the alternator.
What made me notice the pulley was it was getting rust colored dust around it.
Good luck! I hate odd things like that.
