Sudden Loss of power and white smoke
I have been reading a lot this weekend due to a problem with my excursion. Basically, it just lost power and wouldn't go above 30 mph. I do see a coolant leak from top of radiator to the engine at the engine. The truck had a sudden loss of power. Got the water in fuel light on the dash. Towed truck home.
Here are my DTCs
P1000 Check not complete??
P1670 Electronic Feedback Signal Not Detected
P1140 Water in Fuel Condition
P0301 Fault Cylinder A-Misfire Detected (CYL 1)
P0671 Glow plug #1 circuit failure
P0673 Glow plug #3 circuit failure
P0675 Glow plug #5 circuit failure
P0677 Glow plug #7 circuit failure
P1AEE ??
P0008 ??
P08A6 ??
I cleared the codes to see if the return. The truck starts and runs now revs in park fine but I do see some white smoke. Is that vague enough? Let me know if I need to add more info to make sense of this post.
Just trying to figure out how major an issue this might be $$ wise.
Thanks
Here are my DTCs
P1AEE ??
P0008 ??
P08A6 ??
Thanks
First off, this isnt a GM SUV - Its not a car.
Second, with those many fault codes, i'm guessing you should check the ground strap from the engine to frame.
I'm guessing those glow plugs are all on one harness, so probably not the individual glow plugs
Drain some diesel out of the bowl to see if you have any water in it.
Where its leaking from the engine, check for any small cracks, mabye you have a cracked head.
******Edit, our coolant hoses don't attach on the heads, do they? I was thinking of something else, mabye even a tractor or something.... mind is blank...)
Cleared the codes drained the seperator. I then drove it. No new codes appeared but when I accelerate hard I get a nice white smoke cloud and power loss. I easy off a bit and no smoke and running. I can get up to 55 just can't punch it.
Any good posts on how to checking the UVCH? Would it be an all day event for a newbie?
p.s. I edited the offending "car" references.
Hope that is what is is but I have my doubts. Welcome to the site and let us know if the problem comes back. Are you loosing coolant from radiator? Wondering if you are seeing steam instead of smoke. Not good. Other things to check, Oil level, filters. How bad is the leak and where is the water going?
It's happened again...
The problem has come back. Everything seems to be acting the same. Driving can't get past 50... engine bucking then just quites. I towed it home and got it started but would not stay started. Can't restart it now cranks but doesn't turn over.
I am going to try the CPS again heck it worked last time why not give it another shot.
Here are the codes just in case something jumps out at someone. Ones in bold were mentioned the first time this happened.
P0100
P0671
P0673
P0720
P0722
P0732
P1140
P1211 - ICP???
P1670
P0100
P0671
P0673
P0720
P0722
P0732
P1140
P1211 - ICP???
P1670
Using your ohm meter, check the resistance against a good ground on the front 2 and rear 2 pins. They should read between 0.1 and 2.0 ohms. Next check the 3rd, 4th, 6th, & 7th, pin against the center 5th pin looking for a reading less than 5 ohms. Report back to us what these readings are. The most important part about injector readings is consistency. If one is reading off from the others, it may be a solenoid issue. If readings are open, or if 2 or more are out of spec, it's time to pull the valve cover and check for a loose plug. If the plug under the valve cover comes loose, the truck will not run right.
Now just in case you got the CPS from an auto parts store, stop by Ford or International tomorrow and pick up another CPS. The ones from the parts houses have been less than reliable.
Yes, I did check the oil and it was fine. I did replace the CPS but no luck but now it is smoking more when cranking.
Ok, I will do the UVCH check when I get home from work tomorrow and post back. Any pictures where I can make sure I can find it. I can be a bit slow.
Some background... my wife mentioned it has been getting harder and harder for her to start in the morning. It has been chilly for Forida...high 40's at night. Not sure if related but thought I would mention it.
Thanks for the help!
ok here are the readings....
Passenger side back of truck to front on the pins not sure how they are suppose to number
1. .4
2. 2.4
3. 4.9
4 3.5
5----
6. 3.9
7. 3.8
8. .4
9 .4
Drivers side back of truck to front on the pins not sure how they are suppose to number
1. .4
2. .4
3. 4.1
4 4.0
5----
6. 3.8
7. 4.1
8. 3.8
9 .4
ok not sure what to make of those readings. Only one seems out of spec for sure and one close the are both next to each other but would that really be keeping me from starting?
Pull the cover got few things out of the way but I think I would have to remove more to get the cover off maybe not.
Suggestions???
1. .4
2. 2.4
3. 4.9
4 3.5
5----
6. 3.9
7. 3.8
8. .4
9 .4
1. .4
2. .4
3. 4.1
4 4.0
5----
6. 3.8
7. 4.1
8. 3.8
9 .4
Suggestions???
