Air Pump Eliminator Kit
#31
I have a '96 E250 4.9L w/ no a/c. How do I find out what size belt I will need to bypass the smog pump? Mine is VERY NOISY and I assume it will lock up at any minute.
#32
#34
#35
#37
Depends
I have no cat or air pump but I don't get my emissions checked because it's an 89 and I live in nh. Plus I have a guy that stickers my truck as long as it has lights 😂
#39
Hmm
The only reason the air pump is on your truck is for the air to be super heated in the catalytic converter. Ifor it's not working correctly or if it isn't pumping air, you may fail inspection on a sniffer but you might get away with it as long as the o2 sensors don't get pissy
#40
#41
i have a 1990 with the 5.8. my pump froze up and in addition alot of the emission equipment was gone or bypassed before i bought it. i removed the three smog pump pulley bolts and removed the pulley. i found somewhere on this site the belt number, tried it and it worked perfect. the belt number is 6PK2285. im sure that belt number crosses over into other numbers.
79supercab79
11-26-2022 05:59 AM
Dustin_in_PDX
12-17-2017 12:54 PM
Keoneeli1
11-10-2017 01:18 AM
smokeyjo50
19
09-13-2017 05:16 PM
