Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-30-2001, 03:09 PM
winfordr is starting off with a positive reputation.
explorer ac compressor problem
__________________
Winford
06 Mariner Hybrid 4wd
02 Mountaineer 4.0L AWD
88F150, 5.0 ExtCab
54 F100 92 5.0 HO Powered
Previous Vehicles:
71,73 F100, 92 F150
83, 88 Ranger
64 Econoline
91, 98 Explorer
65,68,70,92(2),96 Mustangs
71,75 Pinto
75 Torino
80 Tbird
62,63 Falcon
and a few non-Fords
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 09-08-2001, 09:27 AM
mpriceman is starting off with a positive reputation.
my 2000 explorer has only 15000 miles but after returning it twice to the dealer i'm still having a problem with the compressor clutch engaging every 15 to 30 seconds. i understand this may be "normal", but the loud clicking noise i hear each time this happens is getting very annoying (even at 70 mph on the interstate)-
can anyone offer any reason or solution to this problem and what i should have the dealer do? (he already replace the low pressure switch and supposidly checking the gap setting on the clutch, although i suspect it may not of been done)-
thanks....
mpriceman(No Email Addresses In Posts!)
  #3 (permalink)
Old 09-08-2001, 04:03 PM
Torky is starting off with a positive reputation.
I have heard some clutches on Ford compressors clack on engagement at idles speeds, such that you could hear it plainly at idle in the cab with windows up an fan on. Then on another try, they may be quiet. I'm surprised you can hear yours at 70 mph, that must be a BIG CLACK!
Changing the A/C clutch cycling pressure switch is a 5 min. job, thats probably why they did that. That pressure switch just determines at what system pressure the compressor clutch gets turned on or off. If they really did check the clutch gap, I'd be doubtful too if they really did, then maybe a replacement clutch is in order.
  #4 (permalink)
Old 09-10-2001, 12:54 PM
thanks for the suggestion-
as the a/c works & blows cold it's hard to make a strong argument, but the noise is very annoying.
mp
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
