Engine Bay.. Can I use Tire Foam?
Hi guys. I was wondering if I can safely use tire black on my hoses / intake / anything black?
I'm tired of seeing those water spots and dirt spots five minutes after I give my engine a through cleaning. I use engine bright and then hose everything down. I want my motor to look clean and my surrounding parts shiny. I've used the tire black spray foam before and never had anything bad happen, but I want to make sure I'm not going to catch something on fire. Is there something that is made for this purpose...?
I'd really like to make my engine compartment look as clean as it really is.
Also, what kind of spray on detailer do you use? Miguel's (the red bottle. don't have the bottle handy to get the correct spelling of the name) leaves a residue that streaks and I cannot get off!
Thanks everyone, I appreciate it!
I can tell you an even better trick. Get a cheap bottle of windex style glass cleaner and what ever dressing (tire/vinyl/interior) and spray them both on the engine, suspension, wheel wells, ect. Then start the engine, in about 15 minutes the windex will evaporate and take the dressing with it, leaving a nice finish.
In short, yes you can use tire foam in the engine bay. Just read the label for paint and wire warnings.
I usually spray the Simple green on the engine when it is cold. I first mist the engine bay down with the hose. Then I spray the engine bay with the Simple Green. I let it set for 5-10 minutes and then I lightly spray it off. I think it works well and I'm just very careful as to where I spray the water and Simple Green.
I dont use tirefoam I use the bleach white tire cleaner. Spray it all over under the hood, engine/firewall, radiator, wheel wells, battery, ect. Let sit about 5 to 10 mins then hose it all down with the water hose then crank the engine up and warm it up fully to dry the water out and done. Never had electrical problems with it and it eats the grease off the engine block better than that engine de greaser. That stuff requires multiple uses to clean the engine when I use it by directions but the bleach white cleaner takes it off in one use.
