No topic thread,,, Part 2
Received 5,160 Likes
on
Received 4,135 Likes
on
on
on
on
on
Hello Grant, thought I'd post a picture of that cross member to replace the one that I cut out. This now sits at the same height as the Heidt's front cross member and no longer hangs 3 inches below. Once I get the cab back off the frame I'll weld the nuts to the remains of the old cross member.
on
Received 1,354 Likes
on
on
on
Good morning everyone, hope you and the family get over that bug soon Sherm.
Nice score on those fender Morris, I could have used those for this build, let me know if you come across a set of rear fenders you have no use for, I'm in need of those.
Here's a picture of it installed Grant, I drilled an indexing hole on each side to pry on if needed to line up the bolt holes, the bottom of this cross member is level with the front cross member instead of 3 inches lower of the original.
Good morning Gerry and thanks.
on
