Source for Mileage before Major Repairs
sorry, no idea about any free sources
Mostly the 04-08's so far have been relatively problem free
brakes are the biggest common maintenance item. the 04/05 years had some rough spots that were ironed out by 06 though.
in terms of major repairs, the 100,000 mark is the biggest 1 I can think of. plug change can be dicey. otherwise it's just oil/filter every 3,000 to 5,000 miles...and every 30k? is axle fluid changeout/fuel filter. the transmission for the 5.4 is sealed and non-serviceable supposedly with lifetime fluid
I had some problems with the fuel injectors and the brakes on my 05 with the 5.4. I wonder if they have these fixed with the 08?
I am considering buying an 08 now instead of waiting on an 09 because it seems all of the bugs they had with the 04 and 05 have been worked out by the time of the 07 and 08. I don't really care about style and all of the bells and whistles like a fuel tank with no cap, etc. I want a dependable truck that rides and handles well and will be problem free for years and years. I don't put but about 5-7K a year in miles.
Major component failure is sporadic. If you don't change your oil, or run it low, then your engine won't last as long as one that gets changed every 5000 miles. If you climb 10% grades every day, towing 8000lbs, then your xmsn won't last as long as mine...Depends on the conditions you drive in. There isn't anything that says at xxx miles get ready to replace the injectors, for example. I'd say your shocks will be ok for 10,000 miles if you're nice to it, and your brakes will last a couple of years if you can put up with the dust.
biggest "issue" that keeps cropping up is gas mileage
SASBK Justin
03-21-2014 03:21 AM
