High idle after extended freeway driving
Old 07-02-2008, 10:18 PM
wilevel2's Avatar
wilevel2
wilevel2 is offline
On my 93 Bronco with a 5.0 5 speed i am having idle problems!!!! First of all i have replaced just about everything that can be replaced on this truck, except the tp sensor. My problem is that when i go to work i take the freeway, truck is fine. Up until i get off of the freeway and come to the first stop sign. Then while stopped the idle hangs around 1500rpm and when i take off and shift the idle raises to 2500-3000rpms on its own. At first i thought it was a vacuum leak but i replaced all the vacuum lines, sprayed the engine with ether(found no leaks), replaced the egr due to a misleading smoke test, replaced iac, checked codes and got different ones every time i checked. I'm stumped on this one. Could the tp sensor be hanging up and causing high idle? And i have checked the forums and found some info on the idle screw adjustment procedure but i haven't found the proper way to actually do it. If anyone can help me i'd greatly appreciate it.
Old 07-02-2008, 10:23 PM
skaterbro's Avatar
skaterbro
skaterbro is offline
Two questions. What codes did you get? And, owning a bko, are you registered to this site?
FullSizeBronco.com
Old 07-02-2008, 10:45 PM
DJdemon6696's Avatar
DJdemon6696
DJdemon6696 is offline
the tps and the IAC is the first to things you should chek if bad idle..
replace your TPS thats your prob im 98% shure
Old 07-03-2008, 05:45 AM
alz's Avatar
alz
alz is offline
Don't just replace the TPS. There are ways to test. Look at this.
Ford Fuel Injection Throttle Position Sensor (TPS)
Do not adjust the "idle screw". It is not a idle screw, but just a throttle plate stop.
It sounds as if you may develop a vacuum leak after the engine is hot. Did you check for leaks when cold or hot?
Old 07-03-2008, 09:01 PM
wilevel2's Avatar
wilevel2
wilevel2 is offline
I checked this thing cold and hot. I've checked after a long freeway run. I've tried almost everything that i can think of and pretty much everything others have suggested. I do belong to fsb.com and i didn't get any closer to a solution posting on their site. As for the codes i got they were as follows:31,32,52, and 77. These codes were at different times of checking, not all at the same time. I thought it could possibly be related to the cruise control, because it only happens mainly in the morning when i can use cruise, but in the pm there is too much traffic so i don't use the cruise and it seems to not happen. This weekend i'm going to check the tps voltage and maybe replace the sensor since it has at least 100,000 miles on it.
Old 07-04-2008, 06:15 AM
alz's Avatar
alz
alz is offline
I can't remember, but is the cruise on our trucks vacuum operated?
Old 07-04-2008, 11:17 PM
donnor's Avatar
donnor
donnor is offline
cruise
1993 was the first year for the non-vacuum new style electronic cruise system on the F-Series/Bronco.
dn.
Old 07-06-2008, 07:47 AM
frederic's Avatar
frederic
frederic is offline
Wilevel2,
My truck does this occasionally. Every time it does, I shut off the truck, get out, and spray the springs and pivots on the outside of the throttle body and the problem goes away for about 8 months to a year.
Before you spend money on parts, know that DIRT might be causing the throttle to occasionally stick.
Old 07-07-2009, 04:24 PM
stangbanger's Avatar
stangbanger
stangbanger is offline
mine is doing this... I need to check my TPS. I am getting a code about the same time while driving? Will a KOEO test pickup that code that keep getting thrown?
-Randy
Pumpoperator6
1999 to 2016 Super Duty
04-25-2017 10:45 AM
johnathan merkling
08-24-2016 04:12 PM
Krisverde
09-21-2015 01:41 PM
wjjarvis84
10-04-2012 11:01 AM
greystreak92
1978 - 1996 Big Bronco
03-06-2011 11:16 AM
Quick Reply: High idle after extended freeway driving
