Trans rebuilt, still not right
Just had the trans rebuilt, upgraded internal parts. Left shop and OD light starting flashing as soon as I left the parking lot. Took it back and got code for RSS being out. Replaced RSS, trans worked fine for several miles until crossing railroad tracks then same thing happened. Kept the truck for a couple of days and it was an intermittent problem. Sometimes trans worked good other times OD light flashing. Took it back to trans shop and same RSS code. Trans guy said RSS, connector, and wire is okay. Said wire runs to speedometer and then to engine management computer and could be a problem there. Also said may be issue in rear where RSS gets reading. Does this sound correct? Any ideas?
