1990 Ranger won't start
I have a 1990 Ford Ranger with a 2.9 liter automatic transmission with about 70k miles on it. It recently died and I can't seem to get it running and am looking for some help. It turns over but won't start. I verifed it has spark and checked the fuel pump safety switch which didn't need to be reset. Do I need to take it to a dealer or mechanic to have the codes read? Is there a way to do that myself? Any suggestions you have will be greatly appreciated.
Thanks in advance for your help.
Dave
Dave
After trying to start it for a bit I'd pull a plug and see if it shows signs of getting gas.
Engines need fuel, spark, and spark at the right time. If you are sure you have spark, the most likely cause is fuel.
As silly as it sounds, be absolutely certain there is plenty of fuel in the tank. These trucks are notorious for fuel gauge failures. I have a 90 with the same engine and my fuel guage is out right now.
Fuel pump is another possibility.
Good luck.
Dennis
Good luck.
Dennis
There should be valve on the fuel line somewhere along the manifold; visible when you're standing on the driver's side, as I recall (been a few years). Looks like a tire valve. Use a guage - if you just press the valve stem fuel will squirt everywhere (or it should) - could be very bad news and a hot time in your garage.
Also be aware that these engines had an issue with the "TFI module" aka "Ignition Control Module". Ford had a recall for them years ago, and they're a known problem area on the 2.9s - after being stranded once in my 1990 BII, I alway carried a spare. Module went out 3 times between about 120k miles and 230k miles on the clock.
I don't know if that's your problem, but it's one possibility. The module is on the back of the distributor against the firewall, and there's a $3 tool that helps you get the 2 screws out to remove it easily. When mine would go, the symptoms would be a little sputtering followed by completely dead engine - no spark to fire the plugs. Always happened when it was hot (hot day, running AC, etc).
EDIT TO ADD: Oh, now I see where you said it has spark. If it's a good strong spark, then the TFI is not your problem. But you probably knew that....
Here you go - scroll down to the Voltmeter or the MIL method:
Ford Ranger/Bronco II EEC-IV Testing
98RACE
07-25-2003 11:02 AM
