6 Volt coil ?
6 Volt coil ?
Need something answered here. I have a 6v coil and I pulled the coil wire off today and the end of the wire looked wet. I now some coils are oil filled. Reason I'm asking is I changed the coil out b/c my fairlane quit 2 times going up a hill. It will start back everytime but takes a few seconds.(longer than normal) Does this mean the coil is breaking down and going bad when thr engine comes up to normal temp. This is the coil I swicthed out will doing all that work to the car. It was a old one I had saved b/c I thought it was good. Sounds like time to buy a new one. Thanks Again
Scott B.
Scott B.
scott, replace coil making sure it is mounted where it can get cool air flow. also, replace condensor!!! on 6-volt systems there are small, intense electrical spikes that fry condensor. for explanation of entire ignition system, go to, msn flathead forum- click on- rumble seat tips then flathead visions. scroll down to list and click on- ignition- read it all. this is an exellent source of information for flatties.
Scott
I don't know if anyone else will agree with this but I drove my 51 Merc for over 6 months with a 12 Volt Coil on it.
I only noticed it when I reset the valves as they were in need of adjustment, it was then I discovered the 12 Volt coil.
I replaced it with a 6 volt one and it ran the very same.
For what its worth to you if you have one handy try it.
