parts
06-25-2008, 04:42 PM
on
parts
i'm looking to make a custom intake on the '86, i just need some tubing and stuff. and i don't even know where to start looking, anyone know a place
thanks in advance
06-25-2008, 07:15 PM
Making an engine custom intake is alot more than just getting some tubes welded up. Do you have any plans/designs to go by?
Look in the yellow pages for tubing if you do go that way.
06-25-2008, 09:26 PM
Im assuming you mean like a cold air intake, or something of the sorts?
Im not sure where a guy would get that 3-4 inch tubing, maybe a plumbing shop?
If its an intake for the engine, then ya got me. Theres gotta be some aluminum around you could get welded up though.
06-26-2008, 02:12 AM
on
yeah, kinda half cold air, i just want to get more air in there
06-26-2008, 11:24 AM
I would check out a plumbing shop then. Some metal shops might be able to roll a piece of aluminum and throw a bead on there to whatever size you want too.
06-26-2008, 03:31 PM
on
sounds like a ram air setup to me, pvc from centennial or somewhere similar would do the trick. For the larger size might have to look more industrial retailers. Keep in mind the more air you shove in there the more that has to come out so you might have to look at exhaust work too if you notice your mileage suffering
06-26-2008, 06:56 PM
I did have a bunch of 4'' aluminum tubing kicking around from a semi, I`m not sure where it went.....
06-27-2008, 08:31 AM
Speaking of semi stuff, you could go to one of the semi wreckers in stoon and check around for some tubing too.
06-27-2008, 09:34 AM
on
i might have to check that out
06-27-2008, 09:38 AM
Make sure you take some pics and notes while making it, always neat to see stuff being home made
06-27-2008, 09:48 AM
on
would it get to hot for plumbing pipe ie pvc, it would be alot easyer to work with....
06-27-2008, 10:24 AM
Im sure there is a heat rating on them, but i dont think that it would get too hot.
06-27-2008, 01:30 PM
on
if you go aluminum i can polish it to look like chrome for ya
06-28-2008, 12:08 AM
Hmm wonder what you could do under the hood of my psd if i did the foil delete?
sercalderon
16
01-26-2024 07:36 PM
dirtdude
05-04-2013 10:41 PM
Ragger
2004 - 2008 F150
10-24-2009 03:36 AM
FitchBanjos
03-10-2008 10:53 AM
armenhammerino
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
01-25-2008 07:59 PM
