diesel shop in new orleans
TNT (formerly Gaerhardt's 225-752-9001) on Airline near Highland in BK. I think they have a shop in NO. You could call them and they may recommend a shop for you. I take mine there as opposed to the Dealer. Less expensive than the Dealer, some of my repairs I could have come on here and saved myself alot of money.
it started all of a sudden
no codes either
i dont know if it is an injector going out or what else it can be
i just need help finding the problem so that i can fix it
rough idle, no power, runs like its not running on all cylinders lots of white smoke that smells like diesel fuel expecially on start up
no codes either
no codes either
im getting a little over 20lbs. of boost and rough idle wouldnt be affected by the turbo would it?
the smoke goes away once the engine is fully warmed up
but if i turn it off it starts to smoke again at start up and it is taking longer for it to start than what it use to
any help as to where to start looking would be really helpful
The first thing I would check is the level and condition of your oil. Clean full oil is vital to a good running truck. What type of oil do you have in there and how old is it?
Do you know what the exhaust back pressure valve sounds like when it's closed? Could yours be sticking closed at warm up? Do you know where the ICP sensor is? You might try unplugging it to see if the truck starts any better. Also look for any signs of oil in the plug when you disconnect it.
as far as the rest tell me where with a decription and how its suppose to funtion and i can handle it
diesels are new to me but can work on the gas motor in my jeep (rebuild)
Try this place. I dropped mine off there today to get the trans rebuilt. He knows his PSD chit from what I hear. He sounded real knowledgeable on the phone. He's worked on all 3 of my buddies PSDs, my dad's PSD and he works on all of the PSD ambulance fleet for WJ Hospital too. He's been trained on the PSD stuff too.
Roy's Auto-Tech Transmission & General Auto Repair
Address: 6909 4th St, Marrero, LA 70072
Phone: (504) 328-4400
Where do you live on the WB? I'd offer up some help but I'm heading out of town for work in the AM. Does that Superchips programmer you have do diagnostic code readings? If so check it. Can it do a CCT (cylinder contribution test)? If so , do it and let us know the readings. From your symptoms I'm thinking an injector o-ring maybe? Is there fuel in the oil?
