1995 Explorer Premium Sound System, Wiring Diagram, Amp Location?? Help
Old 03-22-2001, 01:46 PM
berry1234's Avatar
berry1234
berry1234 is offline
I am trying to add a amp to the stock system if a 1995 E.B. Explorer. Does anyone know where the amp is located? Also, I want to tap into the low level signal before it reaches the amp so I can run that to my add on amp. Does anyone know where to get a wiring diagram for the system? Thanks in advance.
Old 08-27-2001, 10:47 AM
KNELSON3's Avatar
KNELSON3
KNELSON3 is offline
I was wondering if you found any information on this problem. I am installing two twelve in subs and I am not getting any bass output out of my subs and I need some help with it.
Old 08-30-2001, 10:42 PM
borland's Avatar
borland
borland is offline
The factory amp is in the right rear quarter panel in the luggage area. Easy to remove, some screws, bolts, etc.
I Just replaced the factory amp on my 95' Explorer. Used a 200 watt, 4 channel amp (AudioVox Rampage). This is a great amp. I got it at Pep Boys for $50 plus tax.
Recommend you replace the factory speakers as I did. I don't think the factory units can handle the extra power, bass, and treble that the new amp puts out. I'm really impressed with the new sounds.
You also need to purchase a ground isolator/level converter. The factory radio drives the factory amp at speaker levels, so you need a level converter for the amp low level inputs. Also, the low level inputs are usually common ground which won't work with your factory radio, thus the ground isolation is required. I bought mine at Radio shack has these for $15 each, you need two, but later saw a 4 channel unit at Kragen for $20.
good luck, borland
Old 09-02-2001, 01:23 PM
edszhi's Avatar
edszhi
edszhi is offline
Does anyone know where the amp is on the 91 4door LXT?
Thanks
Ed
Old 09-04-2001, 10:17 AM
buzz1973's Avatar
buzz1973
buzz1973 is offline
Same place. Rear passenger quarter panel under the plastic.
Old 09-05-2001, 06:11 PM
cotoole's Avatar
cotoole
cotoole is offline
Old 02-28-2014, 02:13 PM
bsmustang98's Avatar
bsmustang98
bsmustang98 is offline
Red face Fuses are good but no power to Radio
I have done everything possible. Stereo worked, turned car of for 5 mins and nothing. Again all fuses possible have been replaced. Please someone help!!!!
rrhu
05-20-2017 09:04 PM
SCREW
6.7L Power Stroke Diesel
10-13-2015 12:16 PM
94e50
08-03-2015 12:14 AM
danielguam
12-27-2008 05:19 AM
Zero108
12-17-2003 12:23 PM
Quick Reply: 1995 Explorer Premium Sound System, Wiring Diagram, Amp Location?? Help
