Visual Injector inspection
Chris is right. You ought to first find a reason to remove and inspect it. Then, and if a fault is indicated, you can look for signs of a bad injector, Oring, or poor compression by comparing a unit from a failing hole to one from a healthy one. No faults indicated by diagnostics means I would not fool with it. The internals of the injector are best left to the folks who know what they are doing.
If you do get to looking and comparing injectors, look for things similar to spark plugs. Excessive oil or carbon build up VS other clean units. Might be an oring, or something internal. Hope this helps. Just saying so because I've done the injector R&R a few times now and there is a difference in the appearance. You would be looking for some serious fouling for a diagnosis. I mean a big difference.
BBsound
1999 to 2016 Super Duty
03-07-2015 09:39 AM
ozone
02-17-2015 09:24 PM
TheRedBeast01
Modular V10 (6.8l)
06-30-2014 11:09 AM
