Cold Air Intake
Search for on 05 ... its all the same
this should work for you...
63-2567 - K&N 63 Series Aircharger Kits, Performance Intake Kit
its 63-2567
its 63-2567
I believe some changes were made to the 08' trucks. I know the 08' 3V gassers got a new spark plug redesign. Havn't seen or heard of a kit out for the 08' however you MAY be able to make an 05'-07' kit work. FWIW an aftermarket intake won't do much power wise, just a tad more intake noise, slightly better throttle response and a hp or two up high in rpms. I have the K&N FIPK2 on my 04'.
Try looking for a predator "ram air thing". Its supposed to allow colder air to get to your intake. You cut a hole in some plastic and it mounts behind your grill. Not sure if there are any real world gains but it looks like it would be helpful. Good luck on your cold air intake and make sure you get one with a really good filter. From what i have read in the diesel segment all aftermarket filters are junk but we have a turbo to protect so filtration is more of a concern.
The Predator hood does look cool! See link below for details...
Suncoast Creations Functional Ram Air Hood for 1999 - 2004 Ford F350 Auto styling 99 - 04 Ford F350 V8 and V10 Gasoline Engine Custom Ram Air Induction Fiberglass Hood - Aggressive styling ram air automotive hood - OEM fitment
