Torque Converter Lockup Issues
Old 06-11-2008, 06:56 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
Originally Posted by tjbeggs
Rick I don't really want to fool the TFT unless I have to. for now I just let it do its think with no intervention. Its usually only one cycle then its warm enough.
Bill-X has found that some of the codes will change to warm sch after the
first full complete stop.
Bill
Old 06-11-2008, 07:07 PM
jdap's Avatar
jdap
jdap is offline
Originally Posted by MADVAN
OD lamp flash?
I would scan the TFT. Possible short or out of range.
If the TFT is showing to cold you will get the cold shift schedule.
Cold schedule in some PCM codes does not allow TC lock until fluid is warmed up some.
Also scan the TC lock to see if PCM sent the sig and the trans ignored for it for other reasons.
It could be locked just slipping. It will not slip code unless it slips while in OD.
Bill
What is the TFT? My first thought was that it was the cold shift thing but because it locks up only in OD I'm not sure? What do you mean scan the TC lock? How does a guy do that? If it was slipping it would feel the same even in OD wouldn't it?
Powerstroked162... I was of the understanding that if the converter isn't locked then the motor side impeller will spin thus moving fluid against the tranny side impeler and thereby spin the driveline. Then when the converter is locked up, the impellers lock together creating a direct drive driveline?
There is no flashing tranny light and when I scan the truck there are no codes other than P1111 which is "Sys pass (No DTCs Available)"
Old 06-11-2008, 08:35 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
The TFT was just a possible reason.
I would also check the TPS sig to the PCM. (.5 to 4 volts)
If the voltage is low you will not have the early TC lock (lower gear).
The lower gear TC lock is from a WOT.
First is to remove the tuner to rule it out.
Check your batt voltage and charging voltage after a restart.
Be shure your connections are good (+/-)
Bill
Old 06-11-2008, 08:39 PM
MADVAN's Avatar
MADVAN
MADVAN is offline
Dam DP
Bill
Old 06-11-2008, 10:11 PM
BEARMAX's Avatar
BEARMAX
BEARMAX is offline
i dont know what mine is doing .if i drive normaly it starts shuttering around 30 mph and i half to kick the od off untill i hit 35-40 mph and kick it back on but if i put my foot into it.it does fine.im hopeing this is an easy fix bec i want to tow my car on a trailer from fl to ohio and back about 2,000 mile round trip next month. its a 93 f350 7.3 auto...doyou think its upforthe trip and what is up with the tranny
Old 06-12-2008, 12:23 AM
jdap's Avatar
jdap
jdap is offline
Bill
I still don't know what the TFT is... tranny fluid temp? If the TPS signal is low wouldn't the engine not run as hard? It runs just as well as before in OD when the TQ converter is locked it just doesn't lock all the time. I will take try taking out the tuner to see if that does anything though. The battery voltage is where it's supposed to be.. no problems there.
Old 06-12-2008, 06:30 AM
MADVAN's Avatar
MADVAN
MADVAN is offline
Yes TFT is trans fluid temp.
The TC is also very temperamental to inputs from the brake light system.
A fault in the system can cause havoc on it.
Bill
Old 06-12-2008, 06:53 PM
jdap's Avatar
jdap
jdap is offline
Bill
How would I know if there is a fault in the brake system? Just look at the lights and see if they are doing anything crazy or what?
Stilllookin
06-27-2017 08:22 PM
asavage
Aerostar
15
07-11-2016 09:24 PM
bigjason_5
20
11-03-2015 04:54 AM
farmpaw
08-12-2001 06:39 PM
Quick Reply: Torque Converter Lockup Issues
