Testing the waters
Testing the waters
hey everyone,
I'm ready to up-size my process from a 3-5 gallon processer to a 50 gallon Appleseed Biodiesel Processor. following this design, http://www.biodieselcommunity.org/appleseedprocessor/
But I think I'm going to go the Dry Wash route.
I would be willing to take the time and post progress pic.s (step by step) and parts list/costs, if you all are willing to help by giving me feedback and suggestions that may improve my processor and filtration set-up.
I understand its been done on other sites, I'm not sure if there are any complete write ups, with pics here. I would like to do this, and I would like your help.
Whats your thoughts?
I just finished building mine from those plans and ended up spending around $400 on everything. My local methanol supply only sells by the 55gal drum @ $300 per so that will be one of my biggest costs. I have a few supplies so far but need to find some more to make it a viable cost saver. Good luck and remember the appleseed plans are just a guide, figure out how you want your plant to run and design your plumbing to fit your needs. This will save you some time in the long run.
Well,
I got the 55 gallon WVO bin built and I have dropped it at the restaurant earlier today.
I also got the 50 gallon short & fat appleseed processor just about completed. I'm at the point where I have to add the thermometer and plumb a WVO inlet tank with a filter screen, and also build the wash tank.
I was leaning toward "dry wash", but I cant seem to find enough info on line about the build, and what I do see here is either time cosuming with gravity feed filters or lots more money to spend on filtration systems and pumps. Also, I have a tuff tame building something I know next to nothing about, so I'm going to stick to the water wash for now. I will follow the simple and trusted design of The Collaborative Biodiesel Tutorial Team's wash tank.
Question:
should I settle out the glycerin in a different tank with a stand pipe design, or should I allow it to settle in the appleseed? From what I had been reading, the water heater type processor wont let all the glycerin to drain. How much of a problem will this be with mist/bubble wash? enough to stress on?
Question:
The reactor is a 50 gallon, just short & fat. I dont have it on line yet because I'm still working on the wash tank (just got the HDPE drum on Tuesday).
I stopped doing the 5 gallon batches and have been spending me free time reading and digesting all the info out there. So the WVO is loading up, I'm sitting on 150 gallons now so ya, I need to get this thing up and running.
I'll let you know how it goes.
I started with these three sites and found many many more as I researched,
Make your own biodiesel: Journey to Forever
Welcome - Collaborative Biodiesel Tutorial Website
http://utahbiodieselsupply.com/
Being that is hot as hell right now and my other hobbie (Jeeps) are waiting for cooler weather, I decided to scale up my production from 3-5 gallons up to a much larger 30-40 gallons. Just learning as I go.
BTW; nice rig - I like the grill and clear corners. The lift and mudders sure does give it that look.
