1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Improve your brake feel.
Old 10-11-2011, 09:10 PM
57meteor's Avatar
57meteor
57meteor is offline
Originally Posted by saz2686
works like a charm! Now you got me scared I may have went a lil to far and covering the hole thing. I did go about three full turns
if you go too far,the brakes will lock up and not release
  #32
Old 10-11-2011, 09:30 PM
Snowseeker's Avatar
Snowseeker
Snowseeker is offline
lol, welcome to the forum.
  #33
Old 10-12-2011, 08:22 AM
raidscsi's Avatar
raidscsi
raidscsi is offline
Kinda unrelated, On the old 88 F150 the Front and Rear brakes were isolated, is this the case with a 2000 Super Duty?
Hypothetically a front brake hose gets cut, do I still have rear brakes?
or the opposite, rear brake line rusts out do I still have front brakes?
  #34
Old 10-12-2011, 04:42 PM
Snowseeker's Avatar
Snowseeker
Yes but very little braking power and only at the last like 1/10 of brake peddle travel.
  #35
Old 12-21-2011, 04:32 AM
artieb's Avatar
artieb
artieb is offline
I was wonering who has braided stainless steel brake hoses? Who manufactures them, Russell? Thanks, Artie
  #36
Old 12-22-2011, 07:23 AM
Snowseeker's Avatar
Snowseeker
make sure they are coated braided lines. Debris gets in the braids and rubs holes in a liner of conventional braided lines.
  #37
Old 12-22-2011, 09:51 AM
artieb's Avatar
artieb
artieb is offline
I ordered a set of 5 kit, 155.00 or so shipped. I don't worry so much about the typical 3 hoses on a brake system. I would almost be inclinded to split the rear brakes hyd. and make each rear hose independant off the frame to caliper. I think I'll be ok with the 5 hose kit from Russell SS braided.
  #38
Old 12-23-2011, 12:43 PM
artieb's Avatar
artieb
artieb is offline
I got my Russell kit # 696490 and the box says for a 4 in lift, although, the description doesn't state that? I don't want pigtails on my hoses. I'll let you know next week, Artie
  #39
Old 12-23-2011, 12:57 PM
barthel's Avatar
barthel
barthel is offline
Make sure you follow the directions for mounting them, don't (like I did) mount them the same way the OE lines came off.
They're tough *******s, I love mine so far.
  #40
Old 11-30-2012, 05:08 PM
sammie0126's Avatar
sammie0126
sammie0126 is offline
Originally Posted by Monsta
I've not been real happy with the brake feel. It's a bit spongy or rather, take a bit more pedal to initiate the brakes. I was reading the F-150 forum and stumbled across a fix. ( https://www.ford-trucks.com/forums/7...-resolved.html )
OK this is a really old thread but I printed it months ago and just had to say - great information once again. I did this today took all of 10 minutes, went about 1 full turn and brakes are much improved! Thanks Monsta
  #41
Old 12-02-2012, 02:45 PM
SuperDutyScaler's Avatar
SuperDutyScaler
SuperDutyScaler is offline
did you do the nut adjustment or the braided lines? i did the nut adjustment three years ago and its still perfect but with 106k on the clock its time for new hoses so i was thinking about braided ones
  #42
Old 03-28-2016, 03:23 AM
Apocalypse's Avatar
Apocalypse
Apocalypse is offline
She sure as hell didn't do the braided hoses in 10 minutes in one full turn lol
  #43
Old 03-29-2016, 09:49 PM
IslandBlueV10's Avatar
IslandBlueV10
IslandBlueV10 is offline
Wow learning something new. I will be trying this. Sometimes it is nice when someone revives an old thread.
  #44
Old 03-29-2016, 11:52 PM
nogo73's Avatar
nogo73
nogo73 is offline
I did braided lines but not the nut took me a couple hours but I was doing the parking brake shoes (due to the parking brake spring exploding) and new hub seals bearings etc.... I am not sure I would want to adjust the nut my brakes feel very solid.
  #45
Old 03-30-2016, 12:20 AM
IslandBlueV10
Ever since I have owned my truck the brake pedal goes almost half way down before engaging. I have had all the brakes replaced, fluid flushed and still never got a good pedal. I have had everything inspected and always told everything is ok. I have had a couple times where I almost got in trouble because of it. I am thinking this is the next best route.
Quick Reply: Improve your brake feel.
