*** Soft Brake Pedal Resolved ***
Old 07-23-2014, 01:55 PM
ocastellan's Avatar
ocastellan
ocastellan is offline
why no photos
  #32
Old 07-23-2014, 02:50 PM
Stewart_H's Avatar
Stewart_H
Stewart_H is offline
Because it's a 6 year old thread so the links to the pics are no longer current.
Stewart
  #33
Old 07-24-2014, 10:26 AM
thewheelman's Avatar
thewheelman
thewheelman is offline
And it's still a problem.....my 05 has just crossed 130k on the clock and every now and then I think the pedal is going all the way to the floor........
  #34
Old 10-29-2014, 06:05 PM
tommyt's Avatar
tommyt
tommyt is offline
Hoping someone can help.
My 2004 Expedition has the same problem however, instead of a screw on the end of the rod inside the break booster, there is a nipple with a pin (see attached picture) Thinking it also turns out like the screw, I grabbed both the rod and the nipple with two pair of needle nose and wilst trying to turn it immediately bent the pin on the nipple.
The nipple is made out of aluminum and has a little pin that inserts into the rod inside the break booster. The pin is split like a cotter pin and is friction fit inside the rod.
When I bent the pin, I tried to bend it back but aluminum doesn't like to bend and so half of the split pin broke off and the other half is cracked. JB Weld is out of the question as I feel it will eventually break causing a serious break malfunction.
Now the dealer doesn't just sell the nipple even though it is easily bent broken or lost. They want you to buy a whole new booster.
Does anyone sell just the nipple? Or maybe a mechanic on these boards may have one laying around in their tool box? I already checked my local dealer.
Any other suggestions?
Thanks.
  #35
Old 05-10-2017, 11:12 PM
lvin4jc's Avatar
lvin4jc
lvin4jc is offline
Hey all, I know this thread is ancient but I wanted to post on here that this just saved my tail on a 2003 Excursion. Replaced all calipers, a new section of brake line. Bled it a dozen times. Even took it to a shop and had the ABS module computer bled. Still had a spongy pedal.
Read this thread, adjusted the actuator rod, presto, better than new!
Props to the OP
  #36
Old 07-03-2020, 01:38 PM
jstihl's Avatar
jstihl
jstihl is offline
I know this is a ancient thread but was wondering if this would work on a 2000 f350 7.3?
  #37
Old 07-19-2020, 03:33 PM
aaron wheeler's Avatar
aaron wheeler
aaron wheeler is offline
It should. I just did this and upgraded to the Expedition brakes on my 97 F-150 and now it stops on a dime.
EDIT: The nuts on mine were 9/16
pomial
1997-2006 Expedition & Navigator
16
09-01-2009 11:18 PM
Stingray42
03-15-2004 03:53 AM
steve1147
01-19-2004 09:28 PM
Quick Reply: *** Soft Brake Pedal Resolved ***
