Everything Air Ride
Everything Air Ride
I was wondering if anybody out there has a Kelderman air suspension installed on there truck. I'm not talking about overload bags here, I believe they have 2 different kits for the late model trucks, one that goes from 6-8 inches for 38s and one that goes from 10-12 inches for 42s. Any experience based info on the performance of this kit would be much appreciated.
Ultimately I am using the info to evaluate weather this kit could be modified to a 1970s late model F250, giving me a head start in the fab work, or if a universal style 4 linking kit will be better.
Also I recently saw a program on TV where they installed F550 rear leaf springs on a F350 for more towing capacity, however in order to keep a nice soft ride while unloaded; they installed an air bag with a double pivot. They added a hinge point back near the bumper that levered against an air bag and at the other end of the lever was where the shackle and leaf spring mounted. The air bags didn't provide huge amounts of travel just enough to allow some comfortable suspension movement when the stiff F550 springs weren't at work. Any experience based info on the performance of this would be much appreciated too.
I don't think so
I haven't had personal experiences with Kelderman's products, but their rear 4-link setup looks good.
However, if you are using the vehicle for off-roading (which I assume you are).
I would just get some of the softer front and/or rear springs available (you know, smallest gas engine reg cab F250), and add airbags to that - that way, if your bags blow out, you have a way to get home
If I decide to go further down the modding road with the bronco I think the next iteration will be full air ride radius arms front and rear. I've heard of guys carrying spare air bags .. kind of like a spare tire.. in case of failure.
I saw that program also with the F550 springs a long time ago.. I can't remember which show it was on though.
truck U is dumb.....
I'll just 3-Wheel it home...
I've been playing around with active suspension systems for a couple years now and don't feel that an airbag blow out is going to be an issue, however sticks do exist and have been known to go threw a tire so anything's possible. Being able to keep the leaf springs would be a BIG plus, that's what really turned me on to the double pivot system I saw on TV, but that's the first time I've seen something like that with a double pivot.
I have never talked with anybody first hand with airbags in a offroad lift kit application, but have seen them on trucks and sandrails at the dunes.
You are correct, the show was Truck U, and the guys on there are lacking tv show quality. My fav is Gears, but Extreme is ok too
