what's the deal with plugs?
Ok, any help will be greatly appreciated. After reading through some different threads i'm more confused. I'm changing the plugs on my wife's '99 V8 Explorer, and went with Autolite plugs. They gave me AP104's, (single platinum). I asked for top-of-the-line autolites, but maybe this was just the best they had in stock. I noticed when removing the old plugs, that the plugs on one side of the engine were different than the plugs on the other side of the engine (due to different polarity). Can i replace the OEM plugs with single platinum plugs? Do they have to be double platinum?
thanks in advance for any help, i'm actually trying to fix what i believe is a misfire or ? issue with the truck (vibration, strange exhaust odor, CEL on), and i was hoping new plugs would do the trick. however, when i put the new autolite AP104's in it didn't help whatsoever (almost seems worse now)
Freak, Autolite plugs are Motorcraft. However, they did give you the wrong ones, you need double platinums, otherwise one side will wear out very quickly and cause misfires. The spark plug wires should also be replaced for best results. The wires do not last much longer than plugs, and will certainly not last through a second set of plugs.
BTW, your light is one, what are the codes?
thanks Backin and Bear.
I haven't been able to check the codes from the CEL yet, i was hoping to fix and not drive to the shop with it running so crummy. i guess i'll try to exchange the plugs for double platinum today, and pick up a new set of wires - are autolite wires recommended as well as motorcraft?
thanks again, i can't stress enough how helpful this forum is!!!
Doesn't sound like the best plan to me. The plugs do not come from the factory with antiseize, and if they are left in too long, they can damage the threads. Also, by the time you notice that anything is wrong, you are already forming carbon deposits, loosing a lot of power, and can have already damaged more expensive components such as the EGR and catalytic converters. It also puts extra stress on the coils and wires, causing them to prematurely fail. Prevention is always better. Those plugs are already overdue, double platinums should not run more than 100k miles. If you use OE spec parts and install them correctly, replacing them will never hurt anything.
reinstalled double platinum autolite plugs, didn't help. i'm picking up replacement autolite wires today (weren't in stock) but as these are approx. $100.00 i'm wondering if this will even help.
truck starts ok and idles find, but once i put in gear it starts almost studdering under the load, even before pulling out of the driveway.
this problem, along with the smell when we first noticed the problem, makes me wonder if there is any hope in thinking new spark plug wires will fix my problem. Hope it's not the c.converter or something else and i'm just spinning my wheels.
Any suggestions?
thanks in advance for any help.
Any suggestions?
Thanks Backin72 and Bear River.
Backin, i don't think i'm experiencing what you went through, my explorer hasn't stalled even once, just feels like it's about to. came home early from work to check the codes from my CEL and the only mechanic near by turned me away as it was close to closing time and he was "short staffed" - ran just good enough to drive, but the more gas i gave it, the more it stumbled, and vibrated like crazy at red lights.
Sounds to me more like a MAF problem. The MAF in conjuction with the IAT and TPS sensors tells the computer how much load the engine is under. It uses this information to determine how much fuel the engine requires. If the MAF goes out, the computer will not add enough fuel, and the engine will stumble. The ignition timing will also be way off, causing a stumble, especially under heavy throttle. I suggest getting a MAF cleaner and seeing if you can't clean the MAF sensor.
You absolutely DO NOT need double platiunums. Ford puts in single platinums from the factory on all late model vehicles. Double platinum plugs give zero performance gains and their is minimum benefit in using double platinums. You should change plugs every 50k for the best performance anyway. I have changed double platinum plugs and have found significant wear AROUND the platinum where the spark wasn't even jumping to the platiunum.
I would go with the recommended Motorcraft plugs or go with Autolites. I have used both motorcraft and autolite plugs and they work super in Fords.
As far as the CEL and poor running, definatly check for DTCs, your just shooting in the dark without checking the DTCs. As for 130k on the origional plugs, thats not good and performance isn't what it could be.
got the codes pulled, "# 3 misfire". guy said the wires are fine, said he can see that # 3 is sparking, just not "firing". plug looked dry to him, so he thinks it might be an injector. also suggested changing the fuel filter and running some injector cleaner through it, but at the same time, better not to drive it!?!?
Any thoughts on these developmets???? As always, any help is greatly appreciated.
