Propane conversion
It can be added, the process is the same as the older diesels:
Bio-diesel, Propane and Alternative Diesel Engine Fuels - Ford Truck Enthusiasts Forums
Might want to keep an eye on EGT's though
I use it on my diesel focus, with a ~30% propane/diesel ratio
Personaly i would not run propane. Propane is a fuel and it can cause detenation in a diesel if you are not very carefull. The computer controls when the injector fire, since propane is a fuel, you could have a early ignition event not controled by the computer which could cause engine damage. Just my .02
