6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Propane conversion
Old May 30, 2008 | 08:08 PM
SUPERDUTY_08's Avatar
SUPERDUTY_08
Propane conversion
can the 6.4 take a propane conversion? I saw it down on TRUCKS once.....
Old May 31, 2008 | 08:22 PM
oilburnr's Avatar
oilburnr
Propane can be used a supplemental fuel for added hp, but I don't think you could convert it to run entirely on propane. Don't know that I would run a propane kit with the 08 though, I would think the regen cycle could cause a problem when on the gas.
Old May 31, 2008 | 08:56 PM
BigF350's Avatar
BigF350
FTE Leadership Emeritus
FTE Emeritus
It can be added, the process is the same as the older diesels:
Bio-diesel, Propane and Alternative Diesel Engine Fuels - Ford Truck Enthusiasts Forums
Might want to keep an eye on EGT's though
I use it on my diesel focus, with a ~30% propane/diesel ratio
Old Jun 1, 2008 | 03:20 AM
SANDDEMON08's Avatar
SANDDEMON08
Personaly i would not run propane. Propane is a fuel and it can cause detenation in a diesel if you are not very carefull. The computer controls when the injector fire, since propane is a fuel, you could have a early ignition event not controled by the computer which could cause engine damage. Just my .02
