List of mileage boosters
Old 05-29-2008, 11:45 PM
AltaEx's Avatar
AltaEx
AltaEx is offline
This has been discussed over and over but I haven't seen a comprehensive list developed. Can we TRY that here - each poster simply copy the latest poster's list and add their own points. (Leave discussions to other threads and just stick to point form itemization. Embellish or create improved comments rather than trash a prior person's item - whether it's rightly or wrongly in the list at all.)
Maybe don't worry about order - it's highly debatable as are my categories
Generally Easy and Cheap
- improve driving style
- remove roof rack crossmembers
- higher tire pressures
- use a winter front in the winter (air dam effect and impoved engine temp.)
- carry less weight
Less than roughly $500
- engine tune up
- after market air filter
- after market exhaust
- diesel chip
Over $500
- change to highway vs offroad tires (reduced rolling resistance)
- remove push bars, etc.
Involves work, testing and uncertain costs and results
- improved aerodynamics
- - air dam
- - underbelly smoothing
- - rear deflectors
- hydrogen generators :-) (just kidding)
Old 05-30-2008, 03:39 AM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
- Scan Gauge II (or similar) to monitor Load, Throttle Position, manifold pressure etc. to help improve MPG driving style.
- carry less weight
- keep your engine clean
- proper weight oil
- verify proper tire alignment
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- Flux capacitor serious...
Old 05-30-2008, 07:09 AM
katiesdad7's Avatar
katiesdad7
katiesdad7 is offline
I found an easier way to save fuel. Get someone else to drive you. :-)
Old 05-30-2008, 10:49 AM
aklim's Avatar
aklim
aklim is offline
That doesn't work as well as the Bussard Collectors.
A highly fictionalized variation of this concept, called the Bussard Hydrogen Collector or Bussard Ramscoop appears in the Star Trek saga as part of the matter/antimatter propulsion system that allows Starfleet ships to travel faster than the speed of light. In the saga, the ramscoops attach to the front of the warp nacelles, where (when the ship's internal supply of deuterium runs critically low) they collect interstellar hydrogen and convert it to deuterium and anti-deuterium for use as the primary fuel in a starship's warp drive.
Old 05-30-2008, 12:24 PM
MarkMoore's Avatar
MarkMoore
MarkMoore is offline
Dude - I'm a Star Terk fan but....
Old 05-30-2008, 01:51 PM
ukmat71's Avatar
ukmat71
ukmat71 is offline
did someone mention flux capacitor ?
click here
Old 05-30-2008, 01:54 PM
aklim's Avatar
aklim
aklim is offline
click here
Holy Crap. It is 15% off. I'm getting mine NOW.
Old 05-30-2008, 06:07 PM
Monsta's Avatar
Monsta
Monsta is offline
Sit. Stay.
Don't buy from them. I bought the engine oil bypass kit to help reduce pumping losses and found that my mileage went UP. I'd like to get the dual o-pipe but won't buy from them. I'll wait until somebody else carries one.
Oh boy...
Old 05-31-2008, 11:57 AM
AltaEx's Avatar
AltaEx
AltaEx is offline
- Vacuum gauge (cheaper?)
- carry less weight
- proper weight oil
- engine tune up
- diesel chip
Over $500
- - air dam
- - rear deflectors
- - trim windshield w/electrical tape smooths airflow, cuts noise and fixes leakes too :-)
- - Vortex Generators (air tabs)
Note: sounds like Vortex Generators beat Hydrogen Generators.
http://www.mitsubishi-motors.com/cor...004/16E_03.pdf
url=http://www.autospeed.com/cms/A_3061/article.html
Old 06-01-2008, 09:40 AM
FordCrusherGT's Avatar
FordCrusherGT
FordCrusherGT is offline
Best way to get better mileage:
Stop driving the Excursion, drive something that gets better mileage instead.
Old 06-01-2008, 11:45 AM
weekendwarriorfsw32's Avatar
weekendwarriorfsw32
weekendwarriorfsw32 is offline
Master of Strokes
If you have the 7.3 you can also try this Clean you out your EBP
Welcome to guzzle's Exhaust Backpressure Sensor Cleaning Maintenance Web Page
Old 06-01-2008, 11:49 AM
scottman70's Avatar
scottman70
scottman70 is offline
Exactly! That's what I did 2 weeks ago! Drving a 25mpg vehicle now and it's nice saving $$$$ I will only drive the Ex for towing, the rest of the time it's parked in the garage!
Old 06-01-2008, 08:17 PM
AltaEx's Avatar
AltaEx
AltaEx is offline
Yes - I guess walking works too. I've added it below..
- walk or take a bus or borrow someone else's car, take a balloon (or whatever involves just not driving the EX which has the benefit of reducing its depreciation)...
- carry less weight
- drive something else (if you have it)
- engine tune up
- diesel chip
Over $500
- Buy something else (if you have to)
- - air dam
- - rear deflectors
Blk04Snake
2017+ Super Duty
11-19-2016 03:33 AM
Wambo
1999 to 2016 Super Duty
06-22-2016 11:31 AM
jxcasey
02-15-2016 10:39 PM
Quick Reply: List of mileage boosters
