My F6 widowmaker wheel replacement experience
Old 10-30-2009, 03:09 PM
CarlH's Avatar
CarlH
CarlH is offline
Wheels
Thanks, Stu. All good advice. I have a mixed set of non-widowmakers on it now which the farmer installed at some time in the past. Big wide tires that are out of scale. I would like to get something more like the originals if possible.
  #32
Old 10-30-2009, 06:02 PM
truckdog62563's Avatar
truckdog62563
truckdog62563 is offline
Marmon-Herrington Man
To me these are your options to keep the truck looking original. First is the stock F-2 16" rim (please excuse the leaf in the pic). It will require that you swap rear ends. Second is a 17.5" tubeless that was an optional wheel on '56 F-250s. Note that it even has the hub cap nubs on the inside of the center like the stock 16" has. Find a set of these and they'll solve all your problems. Third is a wheel you'll never come across, but I include it because I've got it. It's the only other straight 17" wheel I've ever come across that's a non-widow maker. This is a three piece design called a Firestone "AR" mount. It was sourced on '50s era Chevies, but it will fit a Ford too. The hub cap clips on this won't let you mount your stock hub cap. Hope this gives you some ideas. Stu
  #33
Old 11-01-2009, 08:47 AM
CarlH's Avatar
CarlH
CarlH is offline
Wheels for my F3
Thank you for the photos, Stu. Interesting...I have one of those 56 F250 wheels on the truck, but the other three are different. The farmer must have scoured a junkyard for whatever fits.
CarlH
1997 F150
1949 F3
  #34
Old 11-01-2009, 11:08 AM
truckdog62563
Assuming the 17.5 is on one side of the rear, what's on the other side? Maybe a set of those is your answer. If you can find numbers on it I might be able to look it up. Stu
  #35
Old 11-01-2009, 02:00 PM
CarlH's Avatar
CarlH
CarlH is offline
Wheels for my F3
I am out of town on a business trip now, but I will take a look when I get home. Would I find numbers stamped on the wheel somewhere? I didn't see any sign of numbers, but the wheel looks like the one in your photo of the '56 F250 wheel. There is only one of these "original appearing" wheels on the truck. The other rear is a chrome, hot rod appearing wheel with a LT235/85R16 tire. The front wheels are white steel spoked wheels with enormous tires...31X10.5/OR15 LT. A strange brew, indeed.
  #36
Old 11-01-2009, 03:11 PM
truckdog62563
Oh, no sense looking for numbers on the odd three. There should be a number, though, on the one stock looking one if it's like the above 17.5. The number will be stamped probably on the back/concave side opposite the valve stem. Stu
  #37
Old 03-25-2010, 09:31 AM
samthebarber's Avatar
samthebarber
samthebarber is offline
DO YOU THINK THE 1973 24ft Winnebago FIVE LUG WOULD WORK WTH MY F500 TRUCK
  #38
Old 03-25-2010, 09:43 AM
truckdog62563
Yes, they should fit and work very well. Probably the Winnebago has a Dodge chassis, but maybe could be a Ford too. Dodge and Ford of that era used 19.5" x 6" wheels having Budd #89340. You'll find that number on the back/concave side stamped along the edge of the drop center. IIRC, #72070 was an earlier number for the same wheel. If you find different numbers, come back and I'll look them up for you. The bolt pattern is the same 5 lug x 8" circle as your F-500. We've had several members find and use these wheels successfully on there trucks. Here's a picture of one mine that is NOS, i.e. has never been mounted. Stu
  #39
Old 03-25-2010, 09:48 AM
samthebarber
THANKS FOR THE INFO IT WILL HELP BRODEN THE SEARCH..............SAM
  #40
Old 04-16-2010, 09:43 AM
1953f-500's Avatar
1953f-500
1953f-500 is offline
found a set of 19.5 like new with spare on a 1996 winnabago bought the whole rv for 500.00 dollars
  #41
1953f-500's Avatar
1953f-500
sorry 1976 rv
  #42
Old 04-16-2010, 09:51 AM
bobj49f2's Avatar
bobj49f2
bobj49f2 is offline
Received 2,059 Likes on 804 Posts
Sounds like a good deal.
The hardest part of buying the whole RV is getting rid of the rest of the RV. Most junk yards don't really want them because they're mostly plastic and wood.
  #43
Old 04-16-2010, 10:58 AM
truckdog62563
Great find. Even better if the rubber is good. Hopefully you can dispose of the camper with no great hassle. Stu
  #44
Old 05-20-2010, 10:51 PM
MARAUDER46's Avatar
MARAUDER46
MARAUDER46 is offline
I proudly am the new owner of a 1949 Mercury, canadian truck, M155, 3TON dually, 2speed rear end, the first thing i heard was 'it has widowmakers' and i almost didn't buy it, but for 850.00 it's mine, i can't find any Mercury emblems,hood, front grill/parts for it, so it mite be looking like a Ford, but i'm kewl with that, this is the one place that answered all my tire questions in one visit, about rims and tires, i would be interested in the chrome R/V rim covers tho, just to dress it up.
  #45
Old 05-20-2010, 11:09 PM
truckdog62563
Welcome to the group. I'm glad you saved it because wheels are no reason to let it go to the crusher. Especially since alternatives exist. And that's one heck of a rare truck. It'd be a shame to not keep it as a Merc. Stu
Quick Reply: My F6 widowmaker wheel replacement experience
