7.3 can't make power - 1247 low boost
Old 06-01-2008, 02:44 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
Ah, as far as ray is saying. WGC Valve supposed to be normally closed. Maybe it stuck open?
Dan
  #47
Old 06-01-2008, 03:09 PM
rbaker6336's Avatar
rbaker6336
rbaker6336 is offline
Dan
yes,first I would see if I could blow are through valve running and off
it could possibly be the valve or and electrical defugalty
  #48
Old 06-01-2008, 03:50 PM
BlackJeep's Avatar
BlackJeep
BlackJeep is offline
Robin,
Thanks for the picture and diagram. From the diagram it looks like manifild pressure goes directly to the wastegate and to the valve. And the other side of the valve goes to the intake. Does anyone understand how this is supposed to work?
I'll check my plumbing later, but I think it looks like your photo.
Thanks again.
John
  #49
Old 06-01-2008, 04:39 PM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
Originally Posted by BlackJeep
Robin,
Thanks again.
John
The MAP sends boost pressure signals to the PCM. The PCM will operate the wastegate solenoid at a pressure I am not sure of. There is always some pressure put on the actuator even during lower boost pressure keeping it, for the lack of a better word, preloaded. With the wastegate solenoid open pressure is routed via the red tube to the wastegate actuator and opens it. Excess pressure is sent via the green tube to the turbo intake hose. There is probaly more to it than this, but this is the extent of my knowledge. Hopefully someone with more ecperience will chime in.
Like Ray previosly mentioned, make sure the solenoid is normally closed.
And your more than welcome for the pics. Good Luck.
  #50
Old 06-17-2008, 08:27 PM
danskool's Avatar
danskool
danskool is offline
Go Bills !
BlackJeep
John, How did the PSD preform towing on the trip to pocono 500? Did you fix this problem?
  #51
Old 06-18-2008, 05:22 PM
BlackJeep's Avatar
BlackJeep
Dan,
It pulled pretty good. It was typically able to maintain 65-70 with the trailer (9000 lbs) behind it. On the long steep grades I would sometimes wind up at 60 MPH at the top. When climbing long grades at WOT it would max out at 1200 degrees and 16 lbs of boost. This was with the SuperChips in safe tow mode. I got about 10MPG with 80% highway towing and 20% secondary road towing. I only had to shift to 4th gear once, because some economy car got in front of me and slowed me down...
Overall not too bad. I may try adjusting the wastegate actuator (rather than leaving it disconnected).
Thanks for your help.
John
MPD56
6.7L Power Stroke Diesel
1188
12-28-2023 09:04 AM
TexasEX2K
07-05-2012 10:46 PM
Damonkr
03-25-2010 09:04 AM
gr8dane96
03-25-2005 01:23 AM
parker53029
11-08-2004 05:46 PM
Quick Reply: 7.3 can't make power - 1247 low boost
