My Transplant for my 47 (PIC)
Old 05-25-2008, 08:20 AM
RedSkin12B's Avatar
RedSkin12B
RedSkin12B is offline
Well after alot of thinking and debate I decided to loose the Flathead 6 that's in my truck in favor of a Flathead V8....8BA...I found one down in Phoenix for 350....Motor and Trans.... Be going to pick it up here in a couple of days.
Hope all goes well with the Rebuild.
Brad
Old 05-25-2008, 10:52 AM
Snowking's Avatar
Snowking
Snowking is offline
I'm a personal fan of the V8 so I say go for it and good idea alot of parts are more availbe for the V8. You do know that even though it is still a Flathead it is the incorrect flathead V8 for a 47?
Also I remeber several threads of guys looking for replacment 6 cylinders here. If you're looking to part with the old 6 cylinder.
Old 05-25-2008, 12:01 PM
RedSkin12B's Avatar
RedSkin12B
Yeah I know that the 8BA is for a 49 Car....But the closest I could find for the right price. My truck according to the VIN should have had a V8 in it instead of a 6...I think what I'm gonna try is under the hood 50s Rat Rod/ Hot Rod Look with the outside looking stock. Do the usual stuff T5 trans with a 9in rear end....disk brakes on the front...and a nice paint job. I'm hoping to get a nice re-enlistment Bonus if I can get over to Iraq again...and take that money and dump into this project. The 6 needs a good rebuild... I've put new plugs have a Holley carb on it , rebuilt fuel pump and other little things, and it runs...I'll be looking at getting rid of it when the time comes....
Brad
Old 05-28-2008, 09:18 PM
Snowking's Avatar
Snowking
Snowking is offline
I too was looking at the T5 swap, I am very interested in how it works, but I guess as long as my stock tranny doesnèt blow up itèll stay stock.
Old 06-04-2008, 09:41 PM
Ego Flat 48's Avatar
Ego Flat 48
Ego Flat 48 is offline
8BA transplant
Good choice. I will do the same swap. I have a 226ci engine in my truck and will put in an 8rt 8BA. I had the six cylinder completely rebuilt. Trucks also had the 8BA v8 in them in '48.
Old 06-05-2008, 05:03 PM
effie_man's Avatar
effie_man
effie_man is offline
looks good, you should have a lot of fun with that one in your truck!
Old 06-05-2008, 05:52 PM
Virto's Avatar
Virto
Virto is offline
Back to Iraq, eh?
Nothing really to add about your engine, but I'd like to thank you for your service.
Old 06-10-2008, 12:16 AM
51ford fan's Avatar
51ford fan
51ford fan is offline
I also have a 53 Merc Flathead to put in my 51F1 eventually. The old 6 runs reasonably well for not having been apart in 37 years. I like the 6, but I agree the parts are getting harder to find. If it broke down on a road trip I doubt I could find parts to repair it in a reasonable time frame.
Old 06-14-2008, 01:42 AM
RedSkin12B's Avatar
RedSkin12B
Well I got the motor home and have started to break it down. I don't know if I'll start a seperate thread or just use this one... Thought I'd post updates...as I make progress.
Brad
Old 06-14-2008, 03:35 PM
Ego Flat 48
Brad: Thanks for the photos. Looks like you have your work cut out for you. Good luck. Ralph
Old 06-21-2008, 10:06 PM
RedSkin12B's Avatar
RedSkin12B
Well I got it up on an Engine stand tonight and got the water Pumps Pulled off....
<br>
My Son Help'n me out
I also saw that its got the Nylon Cam Gear....I will be replace'n that with a steel one. Talked to a guy that told me about getting stainless Values...and using hard'n valve seats so I could run Unleaded gas..might look into it somemore.
Brad
Old 06-21-2008, 11:27 PM
Snowking's Avatar
Snowking
Snowking is offline
Good pics, just make sure there are no cracks in the water jacket and should be good to go.
Cracks usually are formed between the valve seats and nearest cylinder.
Old 06-21-2008, 11:28 PM
effie_man's Avatar
effie_man
usually the exhaust valve side
Old 06-24-2008, 02:29 PM
petey shoes's Avatar
petey shoes
petey shoes is offline
brad, have hardened valve seats and stellite guides, along with johnson adjustable lifters. works very well- no lead additives needed! i do however use 1oz of marvel for each tank of gas, keeps things clean and shiny. ps- i do run this unit almost every day! just my 2-cents worth
Old 06-24-2008, 10:19 PM
RedSkin12B's Avatar
RedSkin12B
Petey thanks for the advice, that's exactly what I'm gonna do. Well I made alittle more progress. I flipped it over and started take'n out the Pistons....I got all but two of them free tonight....I'll be soak'n and work'n on those two for awhile. Did see something kinda odd on the crank though, looks like a big chunk is missing...You guys advice...Normal?? Anyway here are the pics.
<br>
<br>
<br>
<br>
<br>
Thanks for the input.
Brad
Quick Reply: My Transplant for my 47 (PIC)
