Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 07-24-2000, 02:05 PM
dennispro dennispro is offline
Garage is empty, add now
dennispro is starting off with a positive reputation.
1950 F100 HELP!!!
I'm working on a '50 F100 and I need some info on the motor. I don't have any good web sites for flatheads. The motor has 59A-B cast on the heads. Anybody know what this is?? I need to overhaul the carbs, one is a Ford Model 59, the other is a Chandler Groves(!?!?). I can't find any sourse for kits for these. They sit on a high-rise (about 10" !!) manifold that has a name cast into the side that looks like THICKSLUG, but I'm sure that isn't right. The name is about the size of a dollar, and in this case, is VERY worn out.
I don't think that this is the original motor, and any help I can find to get me started would be greatly appreciated.
  #2 (permalink)
Old 07-25-2000, 03:23 PM
barry barry is offline
barry is starting off with a positive reputation.
1950 F100 HELP!!!
You can go to www.classicar.com and there is 2 very good chat and forum areas to get info on flatheads. it sounds like you have a earlier engine, say early 40's. It has the crab style distributor? The truck should have the 8RT series engine with the side mount distributor. I am also restoring 1950 F-1 pickup.If you need any info, e-mail me at CLUSSY38(No Email Addresses In Posts!) and I will help you if I can.
Barry
  #3 (permalink)
Old 07-25-2000, 03:47 PM
1950 F100 HELP!!!
Thanks, Barry
You are right, it does have the crab type dist. on the front of the motor. According to Flathead Jack, it is a 48 Mercury motor. As I get into this I will send you an e-mail to ask questions. Thanks again
dennis
  #4 (permalink)
Old 10-15-2000, 07:35 PM
sackett sackett is offline
sackett is starting off with a positive reputation.
1950 F100 HELP!!!
The merc crank is the prefered for hot rodding the flathead. Take it and put it into a Ford block, do the appropaite rod change adjustment and you have a "stroked" ford. The merc crank is of better quality "forged" I believe; the Ford is "cast" If your going to rebuild it think about that. I also have a Merc eng (later year) and I wish I had spent the rebuild doing that.
>it is a 48 Mercury
>motor.
Stephen W. Hansen
92 F-250 XLT (120,000 and going strong)
50 F-1 (some assembly required)
shansen@ndak.net
  #5 (permalink)
Old 02-26-2001, 10:09 PM
bigsix bigsix is offline
bigsix is starting off with a positive reputation.
1950 F100 HELP!!!
Tags
100, 1950, 1950s, engine, f100, flathead, ford, glass, moters, original, truck, trucks, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
