flathead question
Old 01-19-2001, 06:19 PM
chenders's Avatar
chenders
chenders is offline
flathead question
I have a few flatheads v8s, 48-53. One came with the crossover in the front and manifolds with provisions for the crossover and one output for a single exhaust. The other had manifolds that has only one output, so I put a dual exhaust on it. Which is the original set up, and how can I get another set of the manifolds with the one output?
Thanks in advance for your many, many responses,
Chris
Old 08-26-2001, 08:46 AM
Wired's Avatar
Wired
Wired is offline
flathead question
The make of the vehicle that the manifolds came off of is needed to figure this out as a larger truck used the crossover in front or vice versa ( I could find out from a mechanic here in Canada and get back to you tomorrow )
Old 03-06-2002, 07:17 AM
STEVE1103's Avatar
STEVE1103
STEVE1103 is offline
flathead question
My Dads 53 Ford had the cross over, look liked the ones on a lot of 54-57 Fords had.
Old 03-14-2002, 07:10 PM
DightonFord's Avatar
DightonFord
DightonFord is offline
flathead question
I have a '46 1/2 ton with a '49 engine. It has the single outlets on each manifold and uses a conventional crossover pipe. I have to earlier engines (early-mid forties and the manifolds are a different shape (bends). I have some excellent pictures of the installed if you want them. I will need some help from the "boss" to download them. Hope this helps...Joshua
Old 03-18-2002, 09:54 PM
jml's Avatar
jml
jml is offline
flathead question
pascalhorse
04-01-2017 12:18 PM
chrislynn5
61
03-02-2017 12:08 PM
abe
02-21-2017 09:58 AM
old409
Ford Truck Parts for Sale
11-03-2015 10:30 AM
Bugg58
04-07-2004 09:46 PM
Quick Reply: flathead question
