Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Brake Guides
- How To Change Disc Brake Pads
Step by step instructions for do-it-yourself repairs
- How To Replace Emergency Brake
How to rear hub seals and parking brake shoes
#31
You can attach them to an e-mail to guzzle _AT_ rbmicro _DOT_ com
edit: I have already inserted the link to this thread in the reconstructed 7point3 site.
#33
I'm not inlove with grease in the gear oil. I wounder what that does to the clutch plate in the limited slip. I give them a very light coat of grease and sidehill the truck both ways right away to load up the bearings. Supose you could do that with a floor jack but its more fun driving it
#35
#36
Steve, the part numbers for the rear wheel seals are 2C3Z-1177-AB and they come in bags if I remember correctly... The o ring which goes on the axle end is E5TZ-4A331-A... Hope this helps!
#39
#41
In most cases you are right. However, there are some ford trucks that do have left hand threads on the drivers side (left side) rear spindle. Also, as noted, use some gear oil in the hub before putting the nut on. Grease alone may not be enough. In fact, I have replaced spindles that people packed with grease. Too much grease on the outer bearing prevents the oil from flowing through the bearing and getting to the inner bearing, causing it to burn up.
**Also I haven't seen it mentioned anywhere but make sure your replace the "slinger" between the inner bearing and seal, it's pretty thin and could be easily forgotten (don't ask how I know)
#42
Just an update for the socket part numbers. Mile Marker makes the socket, # 15009-01 and it is for all F250, F350 and Excursions with the 10.5 rearend.
I found it at AutoZone.com priced at $20.99 with $6 shipping. The OTC 6601 part number is much more expensive at the $40+ range
I hope this helps others.
#44
#45
Whatever you use, make sure the contact surface covers the entire seal when driving it in. Pop is right, a block of wood will work. Just be careful with it. If you put a crimp or nick in the seal, you may have just ruined it. You might use a piece of sandpaper to clean the rust ring around the edge of the hub where the seal starts in. Also make sure the seal is all the way in. Once you have the hub slid on the spindle, have a bottle of gear oil by you and fill the hub up before you slide the outer bearing on the spindle.
