Install guide for 02 F250 CrewCab 6" lift?
Has anyone put together a install guide for 02 F250 CrewCab 6" lift? I have all the parts except for the rear springs but I have the blocks that will work until I get those. I want to try and tackle this but I can use some help and was wondering if anyone has some links that could help me out.
Thanks
Thanks
I have 6" deaver front springs, drop pitman, shocks front/rear, drop shim kit, blocks for rear (waiting on springs), track bar bracket, Front Sway Bar Extended Endlinks, u-bolts. I got the lift used from someone off craigslist. Because of that, it might be missing some hardware so I wanted to make sure by checking a good install guide as well.
1. Contact the seller to determine if he has the installation document or can tell you the brand(s), assuming it was purchased as a complete lift kit or individual components.
2. If you can determine the brand(s), contact the manufacturer(s) to obtain a parts list(s) and installation document(s).
3. If you cannot determine the brand(s), contact as many reputable manufacturers as possible to obtain parts list(s) and installation document(s) to use them as a "guide".
4. Take your lift components to a local (reputable) off-road shop and have them advise you or do the installation of the lift components.
