Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Misc. > Cooling, Heating, Ventilation and A/C
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 05-16-2008, 04:32 AM
mitch150's Avatar
mitch150 is gaining momentum as a positive member of FTE.mitch150 is gaining momentum as a positive member of FTE.
Question Best e-fans?
Wasn't sure where to post this so I'll do it here. who makes the best e-fans for the '05 f150 5.4l? Thanks!
__________________
2005 F150 XL 5.4L ext.cab,longbed 4x4
Volant w/ ram air intake,Magnaflow catback duel exhaust, 3" Bushwhacker flares, Eagle alloys(7 lug rims), BFG All Terrain T/A's, JVC KD-NX 5000 W/ nav, dvd, Sirius, am fm cd w/ 12 disc changer, chrome w2w nerfs, Xcal ll Troyer custom tunes
  #2 (permalink)
Old 05-19-2008, 08:28 PM
Ultramagdan's Avatar
Ultramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to beholdUltramagdan is a splendid one to behold
It's not the fan so much as the fit. You don't want a unit that will rub a hole in the radiator.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
See you in the Kansas Chapter
  #3 (permalink)
Old 05-20-2008, 01:05 AM
mitch150's Avatar
Quote:
That's pretty much what I'm asking about. So no one has any recommendations?
__________________
  #4 (permalink)
Old 05-20-2008, 04:18 AM
phil6608's Avatar
phil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to beholdphil6608 is a splendid one to behold
Hey Steve,
I just got a kit from Troyer.
Make sure it comes with the new mounting system!
My kit came with 2 ways to mount the fan. 1 is the things you push through the rad and the other was a bracket that bolted on top of the fans and on bottom of them.
With the brackets on top and bottom,,,there are no worries about hurting the rad!
Troyer Performance
__________________
Phil
DE Chapter Board Member/New Castle County
2003 SuperCrew
DSS Built Lightning block/Stage 3 heads and cams
L-conversion/Kenne Bell upgrade blower at 18 PSI
BTS/4R100 tranny
100 shot nitrous
1.68 60' time/11.76 @ 116.17
TRUE GRIT!
2000 Grand Marquis
JOIN THE DELAWARE CHAPTER, CLICK HERE
  #5 (permalink)
Old 05-20-2008, 04:24 AM
mitch150's Avatar
Quote:
Originally Posted by phil6608 View Post
Hey Steve,
Troyer Performance
Hey phil. I was looking at what they had and was thinking about the duel fan system, though that's a bit more $$$ than I was looking to spend. How is the fan shroud that comes with the kit as that's 1 of my big concerns. Thanks!
__________________
  #6 (permalink)
Old 05-20-2008, 05:20 AM
phil6608's Avatar
The only shroud is what you see,,,just around the fan.
It is very expensive!!!
I'm sure you could find a less expensive kit that would be just as good!
__________________
Phil
2003 SuperCrew
BTS/4R100 tranny
100 shot nitrous
TRUE GRIT!
2000 Grand Marquis
  #7 (permalink)
Old 05-20-2008, 05:25 AM
mitch150's Avatar
So did u go 1 or 2 fans and how well is it working for u without the original fan and clutch?
__________________
  #8 (permalink)
Old 05-20-2008, 05:35 AM
phil6608's Avatar
Quote:
I went with a LFP single 16" fan with full shroud at first. Worked great for a wile then started having problems with relays/tep sensors.
So I got rid of it and just had the Troyer fan installed.
The kit came with 2 16" fans. Works good but haven't had much chance to test it myself... Trucks been down for a Wile!!!
__________________
Phil
2003 SuperCrew
BTS/4R100 tranny
100 shot nitrous
TRUE GRIT!
2000 Grand Marquis
  #9 (permalink)
Old 05-20-2008, 05:50 AM
mitch150's Avatar
Sorry to hear that, what's wrong with it?
__________________
  #10 (permalink)
Old 05-20-2008, 05:56 AM
phil6608's Avatar
Thanks,
originally,,,a blown head gasket.
Had the motor out to fix it so figured Id upgrade heads and cams.
It was ready to go and one of the new valve springs broke,,,dropped the valve in the cylinder.
Now I need a new piston.
__________________
Phil
2003 SuperCrew
BTS/4R100 tranny
100 shot nitrous
TRUE GRIT!
2000 Grand Marquis
  #11 (permalink)
Old 05-20-2008, 06:31 AM
mitch150's Avatar
Thanks,
OUCH!! Good luck with that phil, and thanks for the info. Still haven't figured out what fan I'll go with yet.
__________________
  #12 (permalink)
Old 05-20-2008, 06:49 AM
I'm using the twin fan set-up. I've had it now for over 3 years and like it a lot. The truck is a lot quiteter. The only downside is that when it's over a 100 degrees outside the AC doesn't cool as well when parked.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #13 (permalink)
Old 05-20-2008, 06:53 AM
mitch150's Avatar
Thanks Dan! Not so worried about a/c sitting still, what with gas prices and all! Did you get yours from Troyer as well?
__________________
  #14 (permalink)
Old 05-20-2008, 05:13 PM
I got mine from StylinTrucks.
__________________
Dan
1998 F250 LD 4X4
Forum Guidelines
  #15 (permalink)
Old 05-20-2008, 07:50 PM
97Handshaker's Avatar
97Handshaker is starting off with a positive reputation.
jusnesmodified.com has a dual 16" fan kit also, ive heard it works pretty good too!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
