Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane and Alternative Diesel Engine Fuels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
Reply This Section Sponsored By
LinkBack Thread Tools
  #1 (permalink)
Old 05-13-2008, 08:27 PM
Tom D is starting off with a positive reputation.
My first successful BD batch
With considerable help from Fabman and Kennedyford, I have finally succeeded in producing a good 25 gallon batch of BD. It was not without problems however. I had trouble filtering out the Magnesol but finally succeeded. I have since ordered some 10 micron bag filters and hope that after filtering through it using gravity feed, I can filter through a 5 and 1 micron filter using a pump without "sheering" the magnesol. Any comments from you guys? Thanks very much FTE and the aforementioned helpers. Tom
__________________
93 F-250 7.3 Banks turbo, 3.5" exhaust 4" ram air K&N filter E40D 4.10. Pyro, boost, & tranny temp gauges. Tru Cool 28,000 GVW trans cooler
  #2 (permalink)
Old 05-13-2008, 10:32 PM
Trent Fliginger is starting off with a positive reputation.
pics? open style? would really like to see it. did you do a smaller processor first?
__________________
Rushmore X, 2003 Excursion (Eddie Bauer) 4X4, 7.3, Hellvig antisway bar, AFE stage 1 w/proguard, 4" MBRP w/ 5" tip, DP tuner, more to follow! Going BIO!!!
  #3 (permalink)
Old 05-13-2008, 10:34 PM
Forgot to ask if you are using KOH or NAOH and where you get yours.
__________________
  #4 (permalink)
Old 05-13-2008, 11:53 PM
fabmandelux's Avatar
fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.fabmandelux has a very good reputation on FTE.
Great news Tom! I told you you'd get it! Glad I could help, and feel free to call me anytime you need help.
__________________
FABMANDELUX.
Don.
To join the Oregon Chapter, click HERE
  #5 (permalink)
Old 05-14-2008, 02:39 PM
do you guys have blueprints for the magnesol drying system that you are using? We are thinking of going this route rather than water washing. Also thinking of getting one of the cones off ebay to weld on the bottom of a barrell for the reactor. Anyone else do this?
__________________
  #6 (permalink)
Old 05-14-2008, 04:22 PM
ALEXVB22's Avatar
ALEXVB22 is starting off with a positive reputation.
I bought my cone from Bossbuck.com I posted a thread with the link in here titled Cone bottoms for our homebrew processesors or somthing similar. do a search.. but any how.. they work great and fit right on there... I would post a pic BUT its not all the way on it and I'm embarised to say I may have ruined one of the cones I bought.
I got the 304 SS one and was trying to weld it to the bottom of a 55gal mild steel drum. NO problem other then $$$ for some 309 welding rod... I have an ark welder. Well. let me tell you if you have an ark welder and are tring to make this thing DO NOT USE IT! Don't waste your money on the rod as the Cone steel IS TOO THIN even at under 40amps!
Instead find a buddy with a cheap-o Mig welder and buy a spool of 309. This is what has to be used to get these things to mate correctly. Otherwise you'll just burn holes and glop nothing on there really.
Alex
__________________
05' F-350, Kingranch, Crew, Dually...
SCT X3_ Coming really soon!
Afe XP Stage 2 Intake_ on its way today!
  #7 (permalink)
Old 05-14-2008, 04:53 PM
BradyCouchman's Avatar
BradyCouchman is gaining momentum as a positive member of FTE.BradyCouchman is gaining momentum as a positive member of FTE.
so what ratio of bio and desil is it? B5 20 100...?
__________________
1970 F-350 Crew Cab long bed
06 Focus ZX3 5 Speed (DD)
SoCal/Hawai'i FTE
Join our Chapter *HERE*
Quote:
Originally Posted by joshc_guitar View Post
its called Mobile City Tx it is a trailer park with a government.
  #8 (permalink)
Old 05-15-2008, 04:01 PM
[I had trouble filtering out the Magnesol but finally succeeded. I have since ordered some 10 micron bag filters and hope that after filtering through it using gravity feed, I can filter through a 5 and 1 micron filter using a pump without "sheering" the magnesol. Tom[/quote]
Does anyone have an answer to this question???
__________________
  #9 (permalink)
Old 05-15-2008, 04:10 PM
Quote:
Yes, open style. No this is my first one and I used 55 gallon drums. I have 2 tanks on my truck so I topped off each one with 5 gallons. That's approx B30. As soon as I burn up that tank, I plan on running B100. Fabman showed me how to build it. Tom
__________________
  #10 (permalink)
Old 05-15-2008, 05:12 PM
was wondering what the magnesol filter looked like, a PVC pipe with a filter sock in it? what are the dimensions? thanks
__________________
  #11 (permalink)
Old 05-15-2008, 06:17 PM
I tried filtering the Magnesol with a 5 micron filter but it clogged. Fabman suggested letting it settle for 12 hours and sucking the BD off the top which I did. I then filtered thrua 5 and 1 micron filter. At no time did I run it through a pump for fear of shearing the magnesol. I'm hoping I can gravity feed it through a 10 micron filter (without waiting 12 hours for sepapation) and then pumping through a 5/1 filter. I'm awaiting an answer to that one. Stay tuned. I used 4"x 8" sock filters in a PVC pipe. Saw the plans here. See if you can search for them. Tom
__________________
  #12 (permalink)
Old 05-15-2008, 08:29 PM
tr0y is new and has a neutral reputation at this point.
Good Job !
__________________
2003 F250 6.0PSD, 4X4, CrewCab, LWB, Airbags, B&W Gooseneck, train horn.
Soon to add 4" turbo back, Guages, and SCT with some tunes, and of course I would bet new headgaskets and studs when the truck tells me it needs them.
  #13 (permalink)
Old 05-16-2008, 09:09 AM
Gun-Driver is starting off with a positive reputation.
Heres a site with the formula for making your cone bottom.
How to make a cone-bottomed processor: Making a cone
I also had the filter clog problem with magnesol. I did the same thing Fabman said to do, after mixing I allow it to settle over night, then pump the bio off the top through a 5 micron sock I then let it circulate through the 5 micron for a while, then through a 1 micron into another barrel. That way I make sure all the bio gets through the 1 micron. (using this proceedure I can filter several batches before the filters clog)
Then it goes through a regular 10 micron diesel filter(the ones used on a fuel tank) then through the absolute 1 micron can filter then into the truck.
  #14 (permalink)
Old 05-17-2008, 10:00 PM
Knotwild is starting off with a positive reputation.
I just got a processor and I have been trying to use Amberlite to wash it. But, it is too slow without a costly tower. I have been thinking about Magnesol and using a Dieselcraft OC 20 centrifuge to spin it out, then use an absolute 1 micron filter. Since I do not have any experience with Magnesol, do any of you think that would be sucessfull?
Thanks
__________________
97, Regular cab 4x4, 5sp, 3" downpipe, 4" MBRP turbo back exhaust, 6637 intake mod, Dieselsite 203 thermostat.
  #15 (permalink)
Old 05-17-2008, 10:48 PM
Quote:
Thanks
No reason it wouldn't. The only question I have is with a capacity of only 10 oz for the OC-20 if your doing large batches and require pounds of Magnesol you would be stopping to clean the rotor a lot.............
My new plant will use something similar, a commercial SELF-CLEANING mechanical driven centrifuge. I found a used unit for $2,500. Not bad when a new unit is over $10,000!
__________________
FABMANDELUX.
Don.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
