temp. gauge not rising????
Old 05-07-2008, 12:20 AM
rhino_160's Avatar
rhino_160
rhino_160 is offline
89 ranger. the temp gauge would always run on the "C" and not in the middle. i replaced the thermostat and it still is only rising to the "C". any ideas? thanks
Old 05-07-2008, 02:20 AM
87 XLT's Avatar
87 XLT
87 XLT is offline
To see if the gauge is working, turn the key to run, remove the wire from the temp sender & ground it to the engine. Does the gauge read full hot?
Old 05-08-2008, 02:48 PM
Aggie05's Avatar
Aggie05
Aggie05 is offline
Where is the temp sender located on a 92 2.3ltr engine?
Old 05-08-2008, 03:42 PM
87 XLT's Avatar
87 XLT
87 XLT is offline
Not sure where it is on a 2.3, but it will be screwed into the head somewhere & has a single wire with a rubber boot that just pulls off.
Wire is red with white stripe.
Old 05-09-2008, 08:48 AM
Aggie05's Avatar
Aggie05
Aggie05 is offline
Anybody know where its located exactly on the 2.3 4banger? Its a 92 ranger xlt.
Old 05-09-2008, 01:32 PM
Aggie05's Avatar
Aggie05
Aggie05 is offline
still seeking more precise location of this thermostat sensor wire. Anybody Anybody Bueller?
Old 05-10-2008, 09:47 PM
Wolfpackdawg's Avatar
Wolfpackdawg
Wolfpackdawg is offline
The search feature is your friend here:
https://www.ford-trucks.com/forums/2...-location.html
It is a bitch to get to.
Old 05-12-2008, 06:18 PM
rangerguy54's Avatar
rangerguy54
rangerguy54 is offline
If grounding it out doesnt work, imply put a manual one in. It costs about 15 bucks at advanced auto and is a five minute install.
