97 F350 -Transmission
Hi there ,
I started to notice yesterday that when I shift from drive to reverse or reverse to drive the trans would make a loud clunk ,,though other times it would go in with no noise. I looked underneath and found some transmission fluid from the drive shaft to the extension housing ( I think that is correct ? ) As i spin the shaft I can see som fluid around the gasket ...any info on what needs to be done woudl be great !
Thanks in advacne ,
Bob B
Thanks in advacne ,
Bob B
Received 1,353 Likes
on
Hi Bob, great to meet you.
From help on your truck re post in the Super Duty And Heavy Duty by clicking on this link: Super Duty And Heavy Duty - Ford Truck Enthusiasts Forums and another useful forum is the Clutch,Transmission, Differential, Axle and Transfer Case: Clutch,Transmission, Differential, Axle and Transfer Case - Ford Truck Enthusiasts Forums
Swing by your local New England Region chapters soon: New England Region - Ford Truck Enthusiasts Forums
Be sure to fill in the location field in your profile soon too!
