1960 f100 engine
1960 f100 engine
I was given a 1960 f100 or f250, not sure which one it is. It has a straight 6 and 4speed on the floor. The engine needs at least a distributor and manifold/carb.
What are there any engines that will be a bolt in swap, I want to get it running as cheaply as possible and later down the road when I'm done fixing it up I might do a big v8 swap.
on
The engine would be, if stock, the venerable 223c.i. I-6 & performance parts are still obtainable for them.
Contact me about a Stock Intake & Carb. for your Olde Girl, if that's what you wish to acquire for her or I'm able to find the Performance parts as well.
on
I stated, "If Stock", as I recollect.
Now, is this the one that was found on that property, pulled out of the folage, had all those Pix & questions posted about it?
If so, then it's a 300c.i. I-6.
I can't keep track of Every individual that posts here, especially when they don't post Pix or state they've another additional thread/s on top of the one here.
Contact away, I'll see what I'm able to do for you.
Depending on the condition, Pleanty.
Watch the classifieds, Craigslist, etc... those engines were used in an awful lot of old Fords, and you might find one that someone's yanked recently to replace with a V8. Or, if there are any old wrecking yards left near you with stuff from that era, you should at least be able to turn up a manifold and distributor.
If you're friendly with a machinist, it is supposed to be possible to fit a newer distributor (like off a 300 six) to the 223. (I think there was a discussion on fordsix.com about this.)
AFAIK the only current aftermarket intakes are from Clifford and Offenhauser, but if you're patient on eBay, other old-school intakes show up occasionally. As far as headers, Patriot makes some that probably fit (can't be sure from the catalog), as well as Clifford.
I swapped in a Y-block with a 4bbl carb, lost 1 mpg, and gained a bunch of power. Not to mention Y-blocks have a sound all their own.
