What size floor jack?
So I wheel my floor jack beneath my new-to-me 1999 stock F-250 4X4 5.4L last night and for the first time since I've had this floor jack I realize just how tiny it is.....
Then again, this truck makes most things look tiny, like my garage for instance.
Anyway, can I get a recomendation on what size floor jack I'll need for this monster?
Thanks,
Stone
Thanks,
Stone
3 ton. I have the Craftsman combo that works great. Use it for the 7.3L and the mustang. The creeper is always good to have also. $129
Craftsman 3 ton Floor Jack, Jack Stands and Creeper Set - Model 50188 at Sears.com
Just Encounterd Floor Jack Death
Literally 2 weekends ago I was doing a tire rotation. I removed the spare, jacked up front left, swapped there, moved to rear right, swapped there, moved on to front right and began to lift, felt like the jack was struggling a bit, then heard and saw it pee'ing jack fluid all over my driveway - my 18-year-old Harbor Freight 2-1/4 Ton Floor Jack just bought the proverbial farm.
My suggestion: get one that's rated for more than 4500 pounds. Of course, one could spend considerable coin for a floor jack, several hundreds of dollars for fancy, lightweigh aluminum ones that won't lift the weight of a 3/4-ton truck w/ a big 'ole diesel engine in it. Personally, I may forego the floor jack route and return to strictly bottle jack use.
While we're (sortuv) on the topic, where does one place a jack (floor, bottle, whatever) to lift so that one can then place a proper jackstand in the proper position for it? I've encountered this on BMWs: the jackpad lift points are for both lifting and supporting, so if the position is being used to lift, you can't place the jackstand there. Instead, one must find an alternate position to lift, leaving the proper jackstand place avaialble for the stand.
Mark
Mark
I have the Michelin 3 1/2 Ton floor jack and it works great. My wife gave it to me for Christmas a year and a half ago. I think she got it at Canadian Tire but in the States I think they are available at Sam's Club.
Very heavy duty jack - weighs a ton but works great. Two piece long handle. I think they are worth about $130Cdn - probably cheaper in the states. Good quality jack for the money in my opinion - perfect for the garage mechanic with a 3/4 ton truck!!
Canadian Tire
Canadian Tire
Thats too bad about the floor jack, I use the same one and, knock on wood, it works good still. Mine is at least 16yrs old, so maybe I still have two years left LOL!!
OK guys, floor jacks are great IF you have a nice hard flat concrete floor to use them on. I have a crushed stone driveway and the jack will not roll like it's designed to when lifting very much in height. I use 4 ton and 6 ton bottle jacks and four 3 ton jack stands to get all four wheels up and solidly supported. I set the jacks under the axles and the stands as far out towards the wheels as I can. I raise the stands up a notch as soon as I have the clearance to do so, just in case the jack should slip. Even when working on the car I will use the bottle jack as soon as I can. I have a couple of scissor jacks that are good for low clearance situations and straight vertical lifting, but I prefer the bottle jacks just for brute strength.
I use a 6 ton bottle jack and 6 ton jack stands from Tractor Supply. I had to get the 6 ton stands, the three's just looked whipmy, and if my head is going to be a foot from it under a diesel engine....... yeah, I'm going bigger than necessary. I went with the bottle jack because it's small enough to carry around in my toolbox and it beats the heck out of the stock screw jack.
sorry to drag up an old post but I am getting ready to do a suspension lift on my truck and was curious as to where would the safest place to put the jack stands on the frame to drop the front axle? then where in the rear is the safest? I have the harbor freight 6ton stands and the 3ton jack which so far have been great but I am now worried the stands won't be tall enough...
