1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
01 f250 6.8 V10 HOW do I replace my PCV Valve?
Old 05-01-2008, 09:28 PM
rg200amp's Avatar
rg200amp
rg200amp is offline
Hey guys, I need some info.
How do I replace my PCV Valve?
Its on the top of the driver side valve cover right?
Do i just remove the the hose and take some vice grips to it, and pull it from the valve cover, then push the new one in + reconnect the hose
THANKS GUYS!!!!
Old 05-01-2008, 10:09 PM
Budman1962's Avatar
Budman1962
Budman1962 is offline
Correct except its on the passenger side valve cover.
Budman
Old 05-01-2008, 10:15 PM
Budman1962's Avatar
Budman1962
You should run your fingers along the PCV hose and check it carefully. They are known to crack near where it goes into intake manifold. I read about this on here and I checked mine. There was a long split where the hose curves. I replaced it and the engine ran much smoother.
Budman
Old 05-01-2008, 11:53 PM
rg200amp's Avatar
rg200amp
rg200amp is offline
I have a rubber hose going from my drivers side valve cover to the intake. I thought this was the PCV. What is that?
Dose anyone have a pic of it? I know its a simple install, its just i want to have all mt ducks lined up.
Thanks guys
Old 05-02-2008, 08:26 AM
kenneBF250V10's Avatar
kenneBF250V10
kenneBF250V10 is offline
That's strange, I have an 01 V10 as well and there is no hose coming off of the driver-side valve cover.
Old 05-02-2008, 08:56 AM
kengarchow's Avatar
kengarchow
kengarchow is offline
i just replaced my pcv hose and the elbow it connects to on my 99 V10
was on the pass side vc
there are two hoses you will need
the pcv hose (has the valve in one end) and the elbow (hooks to the manifold)
total cost a around $25
cured my check eng light left and right bank lean codes
Old 05-02-2008, 12:31 PM
dkf's Avatar
dkf
dkf is offline
I have a rubber hose going from the driver side valve cover to the intake tube on my 04', I believe this is the PCV. here is also a tube on the passenger side valve cover with a corrugated plastic cover on it that looks like it goes to the plastic elbow on the intake manifold that the throttle body bolts on. My trucks an 04' F-250 V10 with no EGR.
grizzlyheart
05-08-2017 06:24 PM
LowcountryF150
33
02-24-2017 07:46 PM
mvvette97
01-10-2015 11:18 PM
zonker27
12-02-2003 09:36 PM
BrianJ77
08-15-2003 09:45 PM
Quick Reply: 01 f250 6.8 V10 HOW do I replace my PCV Valve?
