New processor-first batch
I tried my first big batch (25 gal) today on my homebuilt processor. Other than a couple of small leaks, all went well. Tomorrow I will recover the methanol. I did have a problem filtering the heated WVO through the 5 mic filter bag. I tried gravity feeding it into the mix tank using a 4" PVC pipe as a filter housing. It went VERY slow. Do I need to enclose the filter bag in the pipe and pump (pressurize) the WVO through it to get some flow? If it is this hard now, it will be impossible to filter out the Magnesol later. Any thoughts? Thanks Tom
Try filtering it in stages, 200, 100, 25, and then 5. Maybe not that much but you get the idea. This is what I've been using. The buckets are easier to filter with. 5 Gallon EZ-strainer Filter Biodiesel WVO/SVO oil paint - eBay (item 260233486090 end time May-03-08 10:03:48 PDT)
sirnobody
Bio-diesel, Propane & Alternative Diesel Engine Fuels
04-20-2011 11:04 PM
blkbeast
05-07-2008 04:47 PM
Tom D
04-08-2008 07:44 PM
Tom D
02-21-2007 09:17 PM
