Stage II's, 17* HPOP & GP's this weekend
That Wiki writeup looks pretty good. There are also several others floating around the forums and at vendor sites that sell injectors. I would skip the little oil and fuel galley plugs, just clean out the cylinders. I would recommend you do the injectors first, then the glow plugs. That way any extra fluid can be blown out the glow plug holes. With no glow plugs in, put on the valve covers with 2 bolts each, top off the HPOP, and then jump the starter silonoid. That should clean out the cylinders enough. Then do the glow plugs and keep topping off the HPOP and cranking it to help get the air out. After each cranking you can crack the plugs on the heads and let the air out. Keep doing it till oil comes out the head plugs and the HPOP stays full.
Thanx MagCarl
Question: Before I get started the link recommended that I drain the oil. Now, when I spin the motor over to clear the cylinders I should fill the oil first (duh). But I guess the question is; is it necessary to drain all the oil out before I get started? If I left the oil in the pan I could then spin the motor and fill the rails and clear the cylinders.
Neal, I don't see the point in draining the oil before you start, but I would change it as soon as you clear the cylinders, before you do a lot of cranking to start purging air. The other thing I would add is leave the valve covers off till you get it started, just to verify that all 8 are functioning, pumping oil, no oil leaks from o-rings, etc.
You're missing the point here Glasseater, the glow plugs MUST be removed if you want to blow the cylinders clean and reduce the risk of trying to compress fluid. If you read my previous post you'd see where I told him to put the covers on with two bolts each before spinning the motor. Obviously he would need to remove the valve covers again in order to install the glow plugs and eventually attempt to start his motor.
My Plan
I will leave the old oil in there till after I purge the cylinders with the VC's on. Then install GP's, change oil and filter, add oil to HPOP, purge railstill she fires. Then let run with VC's off to verify all injects are working and oil is flowing thru them.
Sound right?
Thanx to all you guys and reps to those that I can rep.
Sound right?
Yeah Tim the AA's were excelent but the AO's had 4 bad plunger pistons and some extra machine work too. He didn't charge me for the machine work but I had to pay $50 for each piston. $1085 total bill.
I believe I have a good idea what I need to do but it doesn't hurt to ask. This thread has provided me with even more knowledge. Thanx to all.
I will get the specs from your webshots since I can't access webshots here at work. Thanx especially to you.
#29
#30
on
