1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2003 Expedition Rear blend door
Old 06-21-2016, 07:46 PM
Dorzok's Avatar
Dorzok
Dorzok is offline
Originally Posted by Lisatruong630
Very frustrated autozone doesn't carry motorcraft only doorman brand on rear blend door accurator .. Doorman doesn't fit in my 04 expedition .. Any advise
go to the ford dealer and bend over.
i just spent $260 for all three actuators.
  #107
Old 06-21-2016, 08:56 PM
alwaysfords41's Avatar
alwaysfords41
alwaysfords41 is offline
Holy crap. They are like $50 each. I'd say try someone other than autozone. Maybe rock auto.com?
  #108
Old 06-21-2016, 10:10 PM
Action410's Avatar
Action410
Action410 is offline
Autozone and other fast moving parts stores are very price sensitive. They tend to carry several price points and then offer waranties to cover some of the quality.
Dorman isn't exactly top of the line stuff, however people buy it over spending more money so fast moving parts stores carry what moves the fastest. Hense the name fast moving parts stores.
>>>>>>>>>>Action
  #109
Old 07-17-2016, 11:46 PM
Dorzok's Avatar
Dorzok
Dorzok is offline
Still searching. so everyone knows; the blend air actuator under the dash for the front air is for blending the heat and and does not redirect air to the floor or dash or defrost. so apparently i've a vacuum leak someplace. have replaced a few soft connections (stupid ford with their reducing couplings) under the hood. the search continues tomorrow.
  #110
Old 07-18-2016, 05:47 AM
alwaysfords41
We know that, we told you back in June.
  #111
Old 07-22-2016, 01:32 AM
Dorzok's Avatar
Dorzok
Dorzok is offline
here's the thing. got int eh Expy today after work, started it up, and it's blowing full blast out of the dash. i stop at the store (1/2 hour later), get back in, start it up, and back to defrost only.
any ideas?
  #112
Old 07-22-2016, 04:42 AM
alwaysfords41
It is still a vacuum leak.
  #113
Old 07-22-2016, 07:57 AM
alloro's Avatar
alloro
alloro is online now
Received 4,196 Likes on 2,432 Posts
Even if all of the vacuum lines check out as good, the selector switch could be leaking or a diaphragm inside one of the vacuum actuators could have a hole in it.
  #114
Old 07-23-2016, 11:49 AM
Dorzok's Avatar
Dorzok
Dorzok is offline
do you know which of the two actuators control air direction?
ima gonna jump the lines at the control to test that. but i have what seems very little vacuum at the control. i can't feel it unless i stick my tongue on it.
  #115
Old 07-23-2016, 06:41 PM
alloro's Avatar
alloro
I'm fairly certain it's the one at the bottom left next to the driver's right foot.
  #116
Old 11-05-2016, 01:01 PM
Dorzok's Avatar
Dorzok
Dorzok is offline
Finally found the vacuum leak
While replacing the alternator i discovered a shredded vacuum line.
Under here.
It's right there
That elbow.
All is good now.
[***************]Save[/COLOR]
dewjr
08-14-2018 01:59 PM
doc4bax
02-08-2018 01:06 PM
SEPTIC PROFESSOR
01-18-2018 08:27 PM
SEPTIC PROFESSOR
01-06-2018 07:18 AM
bgwho922
07-09-2017 12:25 PM
Quick Reply: 2003 Expedition Rear blend door
