HELP!! E4OD grinding
Old 04-27-2008, 10:57 PM
nwdford's Avatar
nwdford
nwdford is offline
My 1994 F-150 grinds when I put it in Drive for about 20 seconds then makes a horrible clunk sound and then it seems ok. If I put it directly into 1st gear it doesn't make the grinding sound and once I'm moving I can select Drive and it's fine until I come to a stop. Could this be a valve body problem? Or do you guys think the tranny is toast? Any help would be greatly appreciated!
Neil
Old 05-01-2008, 07:30 AM
385seriesHemi's Avatar
385seriesHemi
385seriesHemi is offline
I would suggest a overhaul of the trans.
Old 05-01-2008, 02:02 PM
Tedybear's Avatar
Tedybear
Tedybear is offline
I'm not that great with that series, however if it uses a one-way roller clutch for first gear? I'd say it's probably toasted. One of the tricks to see if it's good or bad on some makes is to use 'drive' gear...and it makes that sound...Then shift to manual 'first' gear..and the sound goes away and everything is normal. The manual 'first' gear uses the clutches/bands, and does not rely on the one way clutch.
S-
Old 05-02-2008, 09:34 AM
nwdford's Avatar
nwdford
nwdford is offline
You guys were both correct, thanks for the help.
96F150-4.9
33
09-05-2020 11:04 PM
amccakes
04-15-2017 09:46 PM
Rays auto
1999 to 2016 Super Duty
09-06-2016 10:49 PM
folsomf250
04-09-2010 07:50 AM
jpm2591
17
10-21-2005 02:25 PM
Quick Reply: HELP!! E4OD grinding
