international Durastar 6.4 vs ford F350 6.4
Hello everybody looking a a few trucks online. I am looking for a big truck to pull heavy loads. I saw the International Durastar truck with the 6.4L (Maxxforce 7) engine I was wondering if anyone new if this was the same engine as the powerstroke 6.4L I know international built the powerstroke but i am cocern if it is the same engine it is rated at 300hp and and 660 torque. Just looking for information thanks.
Hello everybody looking a a few trucks online. I am looking for a big truck to pull heavy loads. I saw the International Terrastar truck with the 6.4L (Maxxforce 7) engine I was wondering if anyone new if this was the same engine as the powerstroke 6.4L I know international built the powerstroke but i am concerned if it is the same engine it is rated at 300hp and and 660 torque. Just looking for information thanks.
Same basic engine with some changes in components and a carbon graphite engine block. Another change is the EGR cooler.
I recall one of the Ford 6.4 forums (forget which one) had a Ford-International part interchange guide that listed the International part numbers for parts that were the same between the engines. I believe much of the external components are different, and I'm not sure if the PCM is as well, I suspect it is. If the PCM is different, then none of the tuners will work.
The DieselGarage.com has the interchange lists.
http://www.thedieselgarage.com/Part_...nterchange.pdf
