It is spring in the Rust Belt
Hey Bob,
Maybe you already tried this but take out the thermostat and see what it does without it. It could also be you have an air pocket but that seems to usually be a problem with newer stuff. Just to eliminate the possibility try hooking up a garden hose to it so that the flow is forced through the engine and start venting any openings for coolant like heater hoses and drain *****. It could be plugged up with sludge someplace. I have had success using a pressure waser in the soft plug holes. You would be surprised at the crap that will come out of a seemingly clean engine.
Two weekends ago it was beautiful outside, in the 60's, and got outside and shot some primer. Last weekend, we end up with 30's and a few inches of snow on the ground. Suppose to be fairly warm this weekend, hopefully we are done with surprises. I agree, its been a nasty cold and long winter.
We have a saying in Wisconsin, there's two seasons, winter and contruction. As soon as the snow stops the orange cones come out and they shut down have of the lanes on the highways.
I did order some more car parts today.
Well, I was able to get some work done on the panel truck today. I retorqued the head bolts. The ones on the passenger side were loose, anywhere from 55-60 ft/lb, they're suppose to be around 70. The driver's side wasn't as bad but still had some loose ones. I swapped in another radiator. The one I put in last fall was from a '46 and I had to switch top tanks because the top tubes were too small. When I did this the cooling tubes looked good and clean but when I brought the truck up from storage this week I had a bunch of leaks. When I took it out tonight I saw about a dozen, or more, leaks. The "new" radiator is out of a '52 F-6 and has three cores. I did find one bad leak when I went to fill it up so I used some epoxy to plug it. It got too late so I didn't get a chance to see it there were other leaks.
I also was able to install an after market temp gauge to verify that the stock gauge and sending unit is working properly.
Ahh, the sweet taste of anti-freeze, the grease stained hands and the small cuts, it's great! Also, the small of oil. Now I just need to hear the sound of the flattie and watch the temp gauge not peg out to the hot side. Everything is great, I have the truck out of storage and the first big swap meet of the year is next weekend. What more can I ask for?
Just an update.
As I was filling the "new" radiator I noticed a somewhat major leak last night so for a quick fix I mixed up a small amount of epoxy puddy and pressed around the leak and left it set for the night. This morning it still leaked so I got a bottle of stop leak and dumped it in. No more leak and I think I fixed the overheating problem, if there ever was one. As I mentioned above I installed an aftermarket temp gauge. Today as I was running the truck to plug the hole the stock gauge pegged out after about two minutes. The aftermarket gauge just sat at the lowest temp mark, 130º. I started to worry after about five minutes and it didn't move. I thought maybe the new gauge was defective. a few minutes later I noticed it slowly move and finall reached about 160º. I left it run for anothr five minutes or so and it just sat at 160-170º. I strongly believe I have a bad stock temp gauge. I might have been chasing a problem that wasn't really there. The radiators were still bad and the one I have in it now I will take in and have properly repaired.
All is good so far
All is good so far
