Who actually uses Royal Purple?
#46
You're In LucK Either Way!
[QUOTE=TheNomad;6123558][QUOTE=Ed;6121804]
Thats what I get for writing on pain pills.
What I was asking is. I know I cant run full Syn in a C6 tranny.
So would it hurt or help to add a qrt of Rp when I change my fluid..
wondering if it would help things run cooler and smoother.
Thanks
Good news! You can use Royal Purple's MAX ATF in your Ford C-6 transmission! (Which by the way, the C-6 is a very good transmission, virtually indistructible! These transmissions were used for towing applications, in the 70s when you ordered say, a STUD Ford Country Squire station wagon, with the 400 CI or 460 CI, these engines were backed with the C-6! These cars towed trailers, car trailers, travel (RV) trailers, boats on trailers ect. This was long before the SUV or minivan was popular, so when families had to move people and had a boat, trailer, ect. chances are the big Fords were used! C-6 transmission did the work)!
You can safely use RP Max ATF, 100%, or, if you wish, you can add a quart, a pint, 1/2 the capacity, ect as Royal Purple Max ATF is 100% compatible with all transmission fluids INCLUDING Dexron II, III, Type-F ATF's.
Royal purple will help cool and lubricate any transmission, and is built to take the heat! In fact, if you have a tranmission without a trans cooler, I would immediately switch to Royal Purple's MAX-ATF!
Of course the key is having fresh, clean, ATF and a clean screen / filter in the transmission. Royal Purple MAX ATF will only add benefits to your transmission, use with confidence, especially in high heat conditions, this is where this quality lubricate really shines!
Even drag racers swear by RP Max ATF, in full race transmissions. If you have a manual FWD transaxle that specifies common ATF, I would also use Royal Purple's MAX ATF! Good stuff!
Your Ford C-6 Tranmission with Royal Purple MAX ATF in the pan =
Thanks
#47
#48
[QUOTE=TheNomad;6124954]Ed your great lol nothing like a party in my Pan.
I asked about using RP in my tranny and I was told it would make it slip in and out of gear..
But Know that I know better I'll have to spread the word thanks man.
Whoever said that, does not know what their talking about. the only exception would be in some motorcycle trans, but not with your specific application.
Use it, even a 1/2 quart of RP will help your C-6 perform as it should and how Ford designed it to!
Ed
Ed
#49
[quote=Ed;6126176]
Please note: Max ATF is not recommended or an approved warranty replacement for: Ford Type F, Ford Mercon SP, Ford Mercon LV, GM Dexron VI, Mercedes Benz NAG-2, Toyota WS, Volvo 5 speed. Max ATF is not recommended for use in any CVT
Ed
Ed
#50
[QUOTE=azfordf100man;6127015]Why is it not recommended for Type F or Mercon? I mean what can you use it in...
#51
#52
Ford Mercon SP, Ford Mercon LV, GM Dexron VI, Mercedes Benz NAG-2, Toyota WS, Volvo 5 speed. Max ATF is not recommended for use in any CVT. Well dang thats a very short list of things you can use with it. Why would they make some thing that you can use in only so few appellations. I guess the only reason so many racers preach about the stuff is they are paid to say so..
#55
I got my RP to try for free due to racing team involvement. The team now pays for Shell Rotella T syn, rather than using and promoting a free product that does not work well for us. If you are paid, of course you preach about it. That is the deal with using racing as a marketing tool.
Jim
#56
Just put Royal Purple 15W-40 in the crankcase today.........NAPA filter and changed the air filter too for good measure.....Never used the stuff, but meaning to. I've got near 100,000 miles on the psd, so I'm getting ready to change EVERYTHING 'wet' over to synthetic. What the hell......I'm paying a little over twice what I'd pay for dino (I ordered it online by the gallon......The truck takes 15 qts.....), but you supposedly can go 15000 to 20000 miles being oil changes.
We'll see.
p.s. Getting ready to change over the tranny fluid to Royal Purple also.
We'll see.
#58
We'll see.
We'll see.
Seriously, be sure to send an oil sample to Blackstone at 7500 miles or so as a sanity check for that 15-20,000 mile oil change interval. You probably can go that far, but not without oil analysis.
Jim
#59
#60
Does 'wet' include the radiator? Actually, you might consider Evans Waterless Coolant, if you want to go 'all the way'.
Jim
Jim
Mainly the oil and the tranny fluid.
Good advice on the rest. I'll definitely look into the coolant (Evans).
Regarding the oil change.....I've BEEN changing every 7500 miles with the dyno.......I'll let this one go prob. 10000 and do the analysis and see how it's working. I want that sucker to run a LONG time.....I love the 7.3L.
