P0381 Glow Plug Indicator Circuit Malfunction
Old 04-10-2008, 09:47 AM
MLCRI$I$ II's Avatar
MLCRI$I$ II
MLCRI$I$ II is offline
Question P0381 Glow Plug Indicator Circuit Malfunction
Can anyone tell me what needs to be replaced when you pull a PO381 GLOW PLUG INDICATOR CIRCUIT MALFUCTION Code?
Glow plug relay? (got a new one on-hand)
Glow plugs? (got a new set of them too)
Glow plug harness? (ain't got that one...yet)
Thanks guys. Any help is always appreciated.
Ernie.
Old 04-10-2008, 09:58 AM
papadelogan's Avatar
papadelogan
papadelogan is offline
Snowboard season cometh..
Check the voltage at the big lugs on your GPR. If you're getting 12v+ on the input side, but nothing on the output side @KOEO (Key On Engine Off) your GPR is toast. Plug her in and keep her warm, and she'll run for you. If you need to replace the GPR, do this one:
Welcome to guzzle's Stancor GPR replacement Mod Web Page
Do it once and pretty much forget about it!!
Old 04-10-2008, 10:06 AM
PaysonPSD's Avatar
PaysonPSD
PaysonPSD is offline
I see you have an EX. Does it have a GPR or a GPCM (Glow Plug Control Mudule)?
Old 04-10-2008, 10:07 AM
MLCRI$I$ II
papadelogan,
Thanks for your quick reply. I have a new Stancor on-hand. Was going to install it last weekend but it's going in there tonight for sure. Had cold start issues this winter when temps were down around 20 degrees or less. Rep Points coming!
Ernie.
Old 04-10-2008, 10:09 AM
MLCRI$I$ II
PaysonPSD,
GPR for sure. New one going in tonight. Thanks.
Would this give me a SES light too? Only pulled one code, but had a SES light this morning.
Ernie.
Old 04-10-2008, 10:21 AM
PaysonPSD's Avatar
PaysonPSD
Not sure about the SES light. After you change the GPR let us know if the SES light clears. Thanks.
Old 04-21-2008, 12:07 PM
MLCRI$I$ II
SES not from a bad GPR...I think
SES light was not from bad GPR. I have a short somewhere in my fuse panel! Just touching or moving the fuse back and forth sets all the dash lights to flash and put on a real show. Touch certain fuses and the truck shuts down on it's own. Both batteries are disconnected and the next step is to open (split) the fuse panel and look at all the connections.
If you ever heard of this problem on the X...I'm looking for suggestions. Has to be a connection ?
Thanks for all your help.
Ernie.
Old 04-21-2008, 01:13 PM
wlihntr's Avatar
wlihntr
wlihntr is offline
your excursion does not have a GPR it has a glow plug control module
Old 04-21-2008, 02:14 PM
MLCRI$I$ II
If you are referring to the aluminum module with cooling fins and 2 wiring harnesses plugged into the side....no, I do not have a GPCM on my truck. I have a solenoid with a shunt.
Old 04-21-2008, 08:06 PM
F350-6's Avatar
F350-6
F350-6 is offline
That's odd. Most Excursions hav the GPCM. Either way it looks like your problem is in the instrument cluster or wiring.
P0381 a Glow Plug Indicator Circuit Malfunction
KD3 DIAGNOSTIC TROUBLE CODE (DTC) P0381
DTC P0381 is set when the PCM detects a malfunction in the glow plug indicator lamp circuit.
Possible causes:
open/grounded circuit
open WAIT TO START light
open fuse. Refer to wiring diagram for fuse number and location.
Key on, engine running.
It's not the glow plugs, GPR/GPCM, it's the circuitry associated with the light. Does your WTS light come on for 1 - 10 seconds as usual?
Since you have seemed to narrow it down to a fuse issue, you might consider removing the fuse panel. The 99 Super Duty's had some issues with a leaking windshield that dripped on the back of the fuse panel. You can look and see if there is any evidence of water on the back of the panel.
Are the fuses loose in the holders or do they just have a bad connection? Any signs of corrosion on the fuse blades?
Old 04-22-2008, 07:49 AM
MLCRI$I$ II
Chris (F350-6)
I am not pulling any trouble codes. When the trucks starts and runs normal the WTS light functions normal. I just touch some of the fuses on the panel and everything shuts down. When it won't start normally after moving fuses around I get a THEFT LIGHT code 16. One blink...pause...six blinks. I don't know that code. Have not found it yet but am search around for the definition. Mess with the fuses a little and all is normal and it starts fine. Just need to touch a fuse or two and everything goes haywire with a dash idiot light show and then dies. Looks like I need to remove the fuse panel torx screws and split the case to see what everything looks like in there. That's where I am at this point. Have a Stancore relay to install but not sure if it will work with the shunt I have on the original solenoid. THANK FOR YOUR ASSIST.
Ernie.
Old 06-01-2011, 10:06 AM
Caliche4u's Avatar
Caliche4u
Caliche4u is offline
hi everyone!!
i get a p0381 code, i have checked the fuses, changed fuel pump, new gpr, new fuel filter. the 2002 f 350 7.3l powerstroke diesel truck cranks but it wont start, any help woud be appreciated!!
thank you very much!!
Old 03-09-2012, 10:36 PM
utahboy1980's Avatar
utahboy1980
utahboy1980 is offline
Had the same problem as Cache
How did you end up fixing it?
Old 03-09-2012, 10:38 PM
utahboy1980
How did you fix it man?
Old 03-09-2012, 11:20 PM
SpringerPop's Avatar
SpringerPop
SpringerPop is offline
This is an ancient thread, and the original poster is likely long-gone.
You would be better-off starting a new thread for your problem.
Pop
canuckelhead
10-05-2013 12:02 PM
sincecrazy
1999 to 2016 Super Duty
01-01-2013 10:54 AM
vfelix702
01-11-2011 08:00 PM
mabc926
08-28-2010 12:51 AM
jcp0003
04-01-2008 02:31 PM
Quick Reply: P0381 Glow Plug Indicator Circuit Malfunction
