Early 94 Keyless Remote Programing
Just received a new Key less Remote for my truck. Searched the Forums and no info on procedures for programing a new remote. Dose anyone out there have any info for me.
I also tried the website that came with the remote and it calls for jumping the pins on the harness below the steering column but there isn't one.
Any and all help would be greatly appreciated.
Gary
Gary
The keyless remote entry module is to the right of the steering column under the dash....
Just searched my 94 CD no operating info as to Keyless entry, schematics only.
FTE has this info re TSB.....
03-18-1***ELECTRICAL - REMOTE KEYLESS ENTRY (RKE) - SERVICE TIPS
Found this:
Ford-Lincoln-Mercury Keyless Remote Programming
<table style="" align="center" background="" border="0" cellpadding="0" cellspacing="0" width="90%"><tbody><tr><td align="left" background="" valign="top" width="100%">1. Turn ignition to RUN or ACC.
2. Momentarily jump pins in programming connector located at the base of the steering
</td></tr></tbody></table>
<table style="" align="center" background="" border="0" cellpadding="0" cellspacing="0" width="90%"><tbody><tr><td align="left" background="" valign="top" width="100%"> column. All doors will lock then unlock to confirm programming mode.
3. Press any button on first keyless remote. Door locks will cycle to confirm programming.
4. If programming a second keyless remote, press any button on second keyless remote.
<table style="" align="center" background="" border="0" cellpadding="0" cellspacing="0" width="90%"><tbody><tr><td align="left" background="" valign="top" width="100%"> Door locks will cycle to confirm programming.
5. Turn igniton to OFF. Locks will again cycle to indicate end of programming mode.
My experience:
-Turned Ignition to ON
-Jumped Programming connector (after jumped doors lock, Clicking sound comes from under dash, doors unlock after 5-8 seconds)
-Pushed Remote button ( nothing happens )
-Turn ignition off ( nothing happens )
Still don't know, Still would appreciate any info
My experience:
Remote Battery's are new.
The reason I purchased a new one was the little hole that holds it on the key ring broke. Its a pain having to find your keys and your key less remote. It still worked perfectly, just wasn't on the key ring.
When i did the above procedure. It cleared the code on the one that worked and won't even let me re program the old on that worked.
Both Remotes I have are the same Product Numbers and the internal boards are identical.
All they guys out there that don't have key less entry are thinking Welcome to the Club.
Alright I figured it out. here is what I did to make it work
under the dash there are 3 wire plug harnesses that connect into the controller for the keyless enty.
I unpluged all three harnesses and re inserted them.
After that the above instructions worked flawlessley.
Hope this helps out anyone in the future.
Happy you talked about the plugs and jumping the pins....I have the same problem you had I purchased a truck and had no key or fob....I have since purchased a fob and I am not sure what pins to jump I only have one black plug under the dash...someone told me I didnt have RKE but the fuse panel has a fuse in the #6 position and is for RKE?
